Results 1 to 13 of 13
Thread: Vitz battery getting dead in 3days
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    Default Vitz battery getting dead in 3days
    yr i tried every battery in my vitz. its getting dead in 3 days. agar main gari chalatey rahoo ga to okei hai. agar 3 din khari reh jati hai to battery dead hojati hai. ye kia prob hai yr.
    Why drink and drive when you can smoke and fly?
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
    speed_manan's Avatar
    Nov 2005
    27
    2,383
    6 Post(s)
    battery is weak...ub change bhi ker lo tom you will say that meri gari petrol keh beghair chalti nahi,kya masla hai hehe
    kidding..get it replaced! battery is dead now! soon it will not even remain charge for a day or few hours..so better get it replaced before that point
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    Alt isnt charging the batt. check charge on voltmeter.
    or the cells of batt arnt good enough to retain the charge.
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    Mach0o's Avatar
    May 2009
    Boston
    46
    48
    As you said you had tried every battery so...
    1: check the generator whether it is charging your batt properly.
    2: Check the wiring, there might be some battery utilization as i had experinced the same. My case was that the dec light remained on while i close the dec and switched off the car, so after a day or so, while i didnt use the car, the batt gets dead... so check out that factor as well.
    If you are talking about a Ride, its Charade, Rest are just Cars...
    Mach0o's Avatar
    May 2009
    Boston
    46
    48
    I mean not just dec light but the factors of battery utilization like mult systems and hell of other factors.
    Zaeem89's Avatar
    Jul 2009
    27
    1,558
    is your car equipped with tracker because they consume battery.
    Digitalphotofreaks.com
    The Photography Forums
    akhterrasool's Avatar
    Jan 2010
    424
    Check the wiring; they might be touching the body from somewhere..
    Farhansa's Avatar
    Oct 2006
    8,715
    5
    84 Post(s)
    get ur generator checked.
    also check wiring.
    UmarAzam's Avatar
    Mar 2007
    27
    520
    5 Post(s)
    Check if u got tracker in ur car bcoz same thing happened to me last year when the battery of tracking device got weak and it also weakens the car battery
    Eat my dust
  10. 23-04-2010, 01:26 PM
    Site Banned
  11. 23-04-2010, 01:29 PM
    Site Banned
  12. #10
    nerry's Avatar
    Apr 2010
    new york
    your battery is local or its need to fill battery water or you can buy warranty battery
    thanks
    _____________
    Rueckfahrkamera
  13. #11
    SaM_vitz007's Avatar
    Jul 2007
    5,821
    4 Post(s)
    Its due to the trakker device.My car's battery used to dead after every 2 days.But when we removed the trakker.This problem never persists. till now.
  14. #12
    sd
    sd is offline
    sd's Avatar
    Sep 2005
    25
    1,400
    3 Post(s)
    ooo must be tracker.. thnx guys..... sub k sub laloo hai. likha hai opr her battery dead kar rahi hai phir bi battery week hai. kash parh lia hota unho ney skool main
    thnx guys for telling tht it happens because of trackers..... thnx sam bhai, umar bhai, zaeem bhai.
    and rest of u guys.: must read carefully den reply okei...
    >>>>D£Ŧƛᵯƛ§Ø ƁØ¥§<<<<
  15. #13
    Jul 2007
    5,821
    4 Post(s)
    2 sd.
    Pleasure brother.
