Closed Thread
Page 18 of 23 FirstFirst ... 81617181920 ... LastLast
Results 341 to 360 of 458
Thread: Swift or Vitz - which is a better option
    sk7242's Avatar
    Mar 2009
    29
    23
  2. #341
    dani123's Avatar
    Nov 2008
    London
    22
    1,702
    swift all the way because its new goood and about vitz it is good but its used recondition
    Just because you're friendly doesn't mean you're insincere Of course..
  3. #342
    guganali007's Avatar
    Aug 2008
    22
    5,000
    Quote Originally Posted by dani123 View Post
    used not recondition..........
    Sent From My Samsung Galaxy S4 Using Fingers
  4. #343
    Sdogar's Avatar
    Mar 2010
    1,520
    23 Post(s)
    @ mehranferrari
    Dear global model of swift is with VVTI for 1.5 L engine only, 1.3 L engine is same as here M13A.See the specs below from suzuki global(:Swiftpecifications | Global Suzuki)
    <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TH colSpan=2>Model name</TH><TD class=unit> </TD><TD colSpan=3>Swift</TD></TR><TR><TH colSpan=2>Body Type</TH><TD class=unit> </TD><TD colSpan=3>Hatchback</TD></TR><TR><TH colSpan=2 rowSpan=2>Engine</TH><TD class=unit rowSpan=2> </TD><TD colSpan=2>Petrol</TD><TD>Diesel</TD></TR><TR><TD>1.3L</TD><TD>1.5L VVT</TD><TD>1.3L DDiS</TD></TR><TR><TH colSpan=2>Drive system</TH><TD class=unit> </TD><TD colSpan=3>2WD</TD></TR><TR><TH colSpan=2>Number of doors</TH><TD class=unit> </TD><TD colSpan=3>3/5</TD></TR><TR><TH class=functionTitle colSpan=6>DIMENSIONS</TH></TR><TR><TH colSpan=2>Overall length</TH><TD class=unit>mm</TD><TD colSpan=3>3,760</TD></TR><TR><TH colSpan=2>Overall width </TH><TD class=unit>mm</TD><TD colSpan=3>1,690</TD></TR><TR><TH colSpan=2>Overall height </TH><TD class=unit>mm</TD><TD colSpan=3>1,500</TD></TR><TR><TH colSpan=2>Wheelbase</TH><TD class=unit>mm</TD><TD colSpan=3>2,380</TD></TR><TR><TH rowSpan=2>Tread </TH><TH>Front</TH><TD class=unit>mm</TD><TD colSpan=3 rowSpan=2>1,470 / 1,480</TD></TR><TR><TH>Rear</TH><TD class=unit>mm</TD></TR><TR><TH colSpan=2>Minimum turning radius</TH><TD class=unit>m</TD><TD colSpan=3>4.7</TD></TR><TR><TH colSpan=2>Minimum ground learance</TH><TD class=unit>mm</TD><TD colSpan=3>140</TD></TR><TR><TH class=functionTitle colSpan=6>CAPACITIES</TH></TR><TR><TH colSpan=2>Seating capacity</TH><TD class=unit>persons</TD><TD colSpan=3>4(3-door), 5(5-door)</TD></TR><TR><TH colSpan=2>Fuel tank capacity</TH><TD class=unit>litres</TD><TD colSpan=3>45</TD></TR><TR><TH class=functionTitle colSpan=6>ENGINE</TH></TR><TR><TH colSpan=2>Type</TH><TD class=unit> </TD><TD>M13A(1,328)</TD><TD>M15A VVT (1,490)</TD><TD>D13A(1,248)</TD></TR><TR><TH colSpan=2>Valve arrangement</TH><TD class=unit> </TD><TD>DOHC-16V</TD><TD>DOHC-16V</TD><TD>DOHC-16V</TD></TR><TR><TH colSpan=2>Maximum output</TH><TD class=unit>kW/rpm</TD><TD>68 / 5,800</TD><TD>75 / 5,900</TD><TD>55 / 4,000</TD></TR><TR><TH colSpan=2>Maximum torque</TH><TD class=unit>N・m/rpm</TD><TD>116 / 4,200</TD><TD>133 / 4,100</TD><TD>190 / 1,750-2,250 </TD></TR><TR><TH colSpan=2>Fuel distribution</TH><TD class=unit> </TD><TD colSpan=2>Multipoint injection</TD><TD>Direct injection</TD></TR><TR><TH class=functionTitle colSpan=6>TRANSMISSION</TH></TR><TR><TH colSpan=2>type</TH><TD class=unit> </TD><TD>5MT/automated MT</TD><TD>5MT/4AT</TD><TD>5MT</TD></TR><TR><TH class=functionTitle colSpan=6>CHASSIS</TH></TR><TR><TH colSpan=2>Brakes(Front)</TH><TD class=unit> </TD><TD colSpan=3>Ventilated disc</TD></TR><TR><TH colSpan=2>Brakes(Rear)</TH><TD class=unit> </TD><TD colSpan=3>Drum, leading & trailing</TD></TR><TR><TH colSpan=2>Suspension(Front)</TH><TD class=unit> </TD><TD colSpan=3>MacPherson strut & coil spring</TD></TR><TR><TH colSpan=2>Suspension(Rear)</TH><TD class=unit> </TD><TD colSpan=3>Torsion beam & coil spring</TD></TR><TR><TH colSpan=2>Tyres</TH><TD class=unit> </TD><TD>165 / 70R14
    185 / 60R15</TD><TD>185 / 60R15</TD><TD>165 / 70R14
    185 / 60R15</TD></TR><TR><TH class=functionTitle colSpan=6>WEIGHT</TH></TR><TR><TH colSpan=2>Kerb weight M/T (min.)/(with full options)</TH><TD class=unit>kg</TD><TD noWrap>3D: 970 / 1,030
    5D: 980 / 1,050</TD><TD noWrap>3D: 980 / 1,040
    5D: 1,000 / 1,060</TD><TD noWrap>3D: 1,045 / 1,105
    5D: 1,065 / 1,125</TD></TR><TR><TH colSpan=2>Kerb weight A/T (min.)/(with full options)</TH><TD class=unit>kg</TD><TD noWrap>3D: 980 / 1,040
    5D: 1,000 / 1,060</TD><TD>3D: 1,000 / 1,060
    5D: 1,020 / 1,080</TD><TD>-</TD></TR><TR><TH colSpan=2>Gross vehicle weight</TH><TD class=unit>kg</TD><TD colSpan=2>1485</TD><TD>1,525</TD></TR></TBODY></TABLE>
  5. #344
    Sdogar's Avatar
    Mar 2010
    1,520
    23 Post(s)
    Quote Originally Posted by guganali007 View Post
    oh i think u did mistake .......interior say lay kay engine tak vitz is better i already proved it....check it out
    Apnay moon mian mithhoo, khud hi arguments day ker khud hi decision de rahay ho ..... LOL
    Koi manay naan manay mairee vitz sub se achee hay...Ha ha ha
  6. #345
    mehranferrari's Avatar
    Dec 2009
    652
    4 Post(s)
    @sdogar
    I saw in few other websites that the car has M13A 16v VVT, but you are correct, it does not mention VVT on the global suzuki site so I am confused myself......still if you see the specs you have posted show that the suzuki swift 1.3 has a maximum output is 68kW/ 5,800rpm and maximum torque is 116nm / 4,200rpm..whereas if you check paksuzuki swift specifications its specifications are 67kw/6,000rpm 114nm /4000 rpm...if the engine is the same why is does this variation exist, is this due to absence of VVT ? or any some other reasons ?
  7. #346
    ibadaslam872's Avatar
    Feb 2009
    18
    6,104
    5
    49 Post(s)
    oye tum phir wapis a gaye... ...bro both of these cars are much better than crapy liana....
    ahahahahahahaha!vitz aur liana its like ghada gari with liana
    Under the Coconut tree
  8. #347
    Aug 2008
    22
    5,000
    Quote Originally Posted by Sdogar View Post
    lol.....parhna to ata hai na ....ja k parh lo sab kuch sahi likha hai ......vitz is the best ....
  9. #348
    Aug 2008
    22
    5,000
    Mod Edit: You have been issued with an infraction for personal attack against a fellow member.
  10. #349
    LianaLover's Avatar
    Apr 2010
    Multan
    25
    813
    Mod Edit: He has been issued with an infraction for personal attack towards you.
    All hondas, toyotas same paki crap stuff, liana is a better offr bt th prob z dat v live in a very materialistc society,wid liana ur a suzuki which is thumb down for certain ppl.
  11. #350
    LianaLover's Avatar
    Apr 2010
    Multan
    25
    813
    +2
  12. #351
    LianaLover's Avatar
    Apr 2010
    Multan
    25
    813
    Quote Originally Posted by LIANARULES View Post
    Bro I don't know why this guy drags Liana in every thread in which I participate..
  13. #352
    HAshims's Avatar
    Aug 2004
    25
    4,885
    39 Post(s)
    3 Thread(s)
    For me Vitz any day for those who says vitz is only 1.0 then have a look at these engine which are offered in vitz
    <table class="infobox hproduct" style="text-align: left; font-size: 88%; line-height: 1.5em;" width="258" cellspacing="5" height="155"><tbody><tr class=""><th style="text-align: left;">
    </th> <td class="" style="">1.0 L 1KR-FE
    1.3 L 2NZ-FE 85 hp
    1.3 L 2SZ-FE 109 PS
    1.33 L 1NR-FE 101 hp
    1.5 L 1NZ-FE
    1.6 L 4ZR-FE
    1.8 L 2ZR-FE 132 hp
    1.4 L 1ND-TV Turbodiesel
    So If Swift is 1.3 ..one can buy 1.3 version of vitz.
    </td></tr></tbody></table>
    Honda Civic 99 EK Hatch / Honda Integra 92 DA Coupe
    RIP Adil( @AridSoul)
  14. #353
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    Quote Originally Posted by HAshims View Post
    1.3 L 2NZ-FE 85 hp
    1.3 L 2SZ-FE 109 PS
    1.5 L 1NZ-FE
    1.6 L 4ZR-FE
    1.8 L 2ZR-FE 132 hp
    +1
    www.facebook.com/performancepartslahore
  15. #354
    Aug 2008
    22
    5,000
    <TABLE style="TEXT-ALIGN: left; LINE-HEIGHT: 1.5em; FONT-SIZE: 88%" class="infobox hproduct" cellSpacing=5 width=258 height=155><TBODY><TR><TH style="TEXT-ALIGN: left">
    </TH><TD>1.0 L 1KR-FE
    1.3 L 2NZ-FE 85 hp
    1.3 L 2SZ-FE 109 PS
    1.5 L 1NZ-FE
    1.6 L 4ZR-FE
    1.8 L 2ZR-FE 132 hp
    very well said +2
  16. #355
    HAshims's Avatar
    Aug 2004
    25
    4,885
    39 Post(s)
    3 Thread(s)
    Discussion ends here ..Question for All of us
    Toyota or Suzuki ? .. yea yea i know many of u answered Toyota.
    JDM FOR LIFE !
  17. #356
    rozzzzz's Avatar
    Oct 2005
    21,924
    12
    140 Post(s)
    5 Thread(s)
    1.3 L 2NZ-FE 85 hp
    1.3 L 2SZ-FE 109 PS
    1.5 L 1NZ-FE
    1.6 L 4ZR-FE
    1.8 L 2ZR-FE 132 hp
    and how much a new 1.3 vitz will cost...
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
  18. #357
    rozzzzz's Avatar
    Oct 2005
    21,924
    12
    140 Post(s)
    5 Thread(s)
    JDM FOR LIFE !
    both of them ....
  19. #358
    HAshims's Avatar
    Aug 2004
    25
    4,885
    39 Post(s)
    3 Thread(s)
    Quote Originally Posted by rozzzzz View Post
    around price of swift
  20. #359
    PGhasanJ's Avatar
    Jul 2010
    26
    935
    point is a 1L Vitz costs about the same as 1.3L Brand New Swift in Pakistan
    as for JDM
    a JDM Swift will be better than a JDM Vitz if u want direct comparison
    and in Hatchbacks Suzuki and Toyota r about the same
  21. #360
    Sdogar's Avatar
    Mar 2010
    1,520
    23 Post(s)
    Quote Originally Posted by mehranferrari View Post
    @sdogar
    Dear,
    I have checked all the european countries suzuki websites and on all of these no VVTI for 1.3L, you can check it yourself, it is confirmed. I think the difference you mentioned is very little and the same engine is being used,
Closed Thread
