Results 1 to 11 of 11
Thread: Vitz new model SHif Lock button
    faisal17pk's Avatar
    Sep 2006
    32
    180
    Default Vitz new model SHif Lock button
    Does any body knows what does shift lock button do in new Vitz?
    Havnt found anything about it in any thread, so thought it will be useful to every1 if some one tried it?
    affan555's Avatar
    Mar 2010
    Shenyang
    26
    893
    3 Post(s)
    according to my info when ur car is switched off and u want to push it if ur car battery is down or in case of any other prob,u can shift the *** from parking p to neutral n by pushing that button.
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    it is there so that you may move the gear level when the car is off.
    chinyoti's Avatar
    Sep 2005
    27
    11,965
    5
    108 Post(s)
    5 Thread(s)
    some how i think its there to change the gear to N (neutral) without using the key, to move the car.
    But in my Vitz it only works when the key is turned to (ON) position
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    faisal17pk's Avatar
    Sep 2006
    32
    180
    Thanks guys. will give it a try today just to confirm.
    faisal17pk's Avatar
    Sep 2006
    32
    180
    You all are correct, checked it myself. Its used to move Gear lever from P to N withought Putting key in it.
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    Quote Originally Posted by chinyoti View Post
    Well that makes good sense, you don't have to start your car.
    And i guess by turning key to ON position it also frees up the steering wheel.
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    Quote Originally Posted by faisal17pk View Post
    Did your steering get free or stayed locked?
    ghufran_sidd's Avatar
    Aug 2008
    32
    17
    thee is another thing when u start the engine then first u were press the brake pedal there is alink btween brake pedal and shift lever first u press the brake then ur shift lever works . suppose ur vehicle having some trouble then u will press this button for shift it to neutral..
    faisal17pk's Avatar
    Sep 2006
    32
    180
    Quote Originally Posted by iLLDuDe786 View Post
    Good point made, will check it today and update accordingly..
    faisal17pk's Avatar
    Sep 2006
    32
    180
    Quote Originally Posted by ghufran_sidd View Post
    Yes theres a link, you can not move from P to any other gear untill and unless you press brake pedal...
    And this shift lock is when i guess your car is having any trouble or for toeing purposes..
