Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 42
Thread: vitz brake issue while the ac is on on CNG
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    Default vitz brake issue while the ac is on on CNG
    at the speed of 5 -10km if i leave the accelator and apply the brake the brake pedal becomes hard like a rock and car doesnt stop
  2. #21
    junaid492's Avatar
    Feb 2009
    26
    115
    Quote Originally Posted by benaam View Post
    bro i had the same problem but i got it fixed now even on ac my brakes are fine there is a mechanic at tariq road his name is niaz he fix this problem i went to many mechanics and even toyota shahra-e-faisal and drive-in but no one was able to even recgnise the issue but this mechanic solve the problem in very reasonable rates..his workshop is at tariq road..
    well i cant come to karachi for that ...if u could help us by telling the problem
  3. #22
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Normaly the brake vacume pipe connected to the engine there is a small valve in that plastic pipe that will not alllow pressure to go both way. try to check that if its working fine.
    I had same issue with charade but it was not that but, With corolla i never faced this issue.
    Speed costs money, how fast can you afford to go.
  4. #23
    Hassan223's Avatar
    Sep 2006
    30
    95
    Brother if u r still in trouble then dnt hasitate to give me a call @ 0321 - 4430780 .
  5. #24
    benaam's Avatar
    Apr 2008
    32
    253
    bro as vaqas said its vaccum issue..mechanic has dissconnected the vaccum pipe which is connected with engine that resolves the braking issue he also had done some kind jugaad in it because if u dissconnect vaccum pipe with engine ur car will not start so ill confirm with mechanic then ill tell u..or ill give u his number u can call & confirm with him..
  6. #25
    khurrammaniar's Avatar
    May 2006
    28
    20
    Its because of the vacuum pipe that`s present in cars that run on CNG....I was facing the same issue...Get the vacuum pipe changed .... Removing it and then putting it back might also help...try that first....
  7. #26
    hassanazeem's Avatar
    Aug 2009
    30
    1,181
    2 Post(s)
    any1 know some mechanic from islamabad that might have the expertise in solving this issue... my vitz has been doing this alot lately and have had quite a few close calls...
    @sameer bhai: i'm waiting for a name from your...
    My heart is a Flat 4!! 62' VW Type-1, 76' VW Sunroof SuperBeetle... To me my VolksWagen, to you yours...
  8. #27
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    but how it is ok on petrol if that pipe is faulty
  9. #28
    chinyoti's Avatar
    Sep 2005
    27
    11,949
    5
    105 Post(s)
    5 Thread(s)
    @asad, pay ur Cng guy a visit, probably he has customers coming with the same issue and if theres a solution he knows it better.
    People i noe in Karachi Vitz owners club who have there Vitzes on CNG nd faced this issue are
    @OptimumSS
    @Rawfay
    They both have there Vitzes on Cng nd jahan tak i remember they faced a similar issue. PM them for a quicker response theyll guide you what they did on there cars to rectify the issue, and with there help you can also guide your cng mechanic what to do exactly
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
  10. #29
    Rawfay's Avatar
    Sep 2007
    26
    1,034
    ^thanks. I've made a thread on the solution for this.
    https://www.pakwheels.com/forums/cng...king-issue-cng
    1. Live and LET Live !
  11. #30
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    i do the same but brake issue remains the same with AC
  12. #31
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    4 Thread(s)
    @all
    the problem arises when your idle is set too low on CNG,.. then it gets worse with teh AC on as the AC causes the engine to slow down even further,.. what you need to do is get the ilde set to compensate for this issue.
  13. #32
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    idle rpm is ok its same as it on AC n without ac
  14. #33
    atherrr's Avatar
    Jun 2009
    Toronto
    24
    446
    Yeah it happens sometimes...althought my car is on petrol...but when im parking it wid ac on nd moving it forward nd reverse at 2 or 3 km speed.....the brakes become hard...becasue the pressure is not built....
    Religion and Science are not at odds, Science is just too young to understand.
  15. #34
    sbaig2's Avatar
    Sep 2007
    55
    39
    Default vitz brakes
    bhi mechanic nay kiya kiya tha, issue kiya hai, mai apnay mech ko kiya kahoon kiya karay
  16. #35
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    dont have any such issues in my platz at least. its the same as a 1.0 vitz. i m running it on CNG for last 3 years. have done around 60 thousand kilometers in it..long routes, short routes, flats, hills..everything...just no problem at all
  17. #36
    mercielago's Avatar
    Apr 2004
    31
    256
    @asad1
    problem is with the advancer of ur car
    check ur advancer and if possible replace it with Landirenzo crank shaft adavancer to get maximum result of CNG from engine.
    MUHAMMAD ASIM
  18. #37
    engr.awaisiqbal's Avatar
    Jul 2010
    37
    45
    I think check the front and rear brakes from mechanic. get them serviced and get them bleed and try to lower idle rpm on cng it should not be more than 1 k
  19. #38
    Navigator's Avatar
    Aug 2009
    47
    114
    There is a mechanic in Lahore at Hakim Chok, Called Haji Sahib, The guy has resolved the problem of many Vitz. The issue is niether of tunning nor the brakes. He will remove the Venturi and Install an injector in the throttle body, few more adjustments and u will never have any problems with the Vitz on CNG.
  20. #39
    OptimusSS's Avatar
    Oct 2007
    26
    2,247
    Quote Originally Posted by Storm View Post
    @all
    +1
  21. #40
    afnan_88's Avatar
    Jun 2005
    Dubai
    28
    2,405
    8 Post(s)
    i m also having this issue in my jap alto cng . . .
