Results 1 to 4 of 4
Thread: Vitz breaks issue while AC is on...
    naqviali's Avatar
    Oct 2006
    Quetta
    45
    40
    2 Post(s)
    Thumbs down Vitz breaks issue while AC is on...
    Dear Members;
    Will highly appreciate support in understanding this strange phenomena.
    I have a Vitz 2001 model. The CNG is added by the previous owner. The issue is whenever I turn the air conditioning on, I have difficulty in applying breaks. The break paddle get too tight (slang main, danda ho jati hai). It's more cumbersome on CNG and less on Petrol on lower speed. On higher speed the break works fine and the paddle is soft.
    What is the reason, my mechanic says that it is usual with Vitz and every Vitz has it, I am not buying this argument, please help....
    chinyoti's Avatar
    Sep 2005
    27
    11,965
    5
    108 Post(s)
    5 Thread(s)
    Similar thread running refer to it.
    https://www.pakwheels.com/forums/cng...e-while-ac-cng
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    naqviali's Avatar
    Oct 2006
    Quetta
    45
    40
    2 Post(s)
    Thanks dear for sharing this...
    Kruso's Avatar
    May 2010
    51
    78
    Its not a big issue as I'm sure the Vitz club has made it out to be. I'm sure its due to lack of vac due to lower RPMS. Just circumvent the whole issue by getting your CNG tuned to a higher idle RPM for the booster.
    Kruso
Tags for this Thread
