Results 1 to 3 of 3
Thread: Vitz Compressor issue
    netlogins's Avatar
    Nov 2007
    36
    15
    Default Vitz Compressor issue
    Hi All,
    I've vitz 2005, 38k driven. Two months back its compressor stopped working so I changed it with clutch based (originally it had sensor based) compressor, on mechanic's advise.
    though new compressor works perfect but if car is 'D' on stop and starting ac after tripping, cause a greater vibration depending on fan's speed. sometimes it vibrates so badly that i feel engine is going to stop.
    after installing clutch based sensor, I had to change it's pulley, as clutch based had 5 pk lines so i've to change it with 6.
    few days back i got an issue in that magnet and pulley and it was jammed which resulted in belt's loss.
    I've to change whole pulley set again along with belt. Kindly advise me what to do to stop this vibration and help me improve its performance.
    I would really appreciate your suggestions.
    Thanks,
    Regard,
    Imran
    Ï ïïïº ® ´¿ð´ ñ
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    I think you should get the sensor based compressor installed again.
    netlogins's Avatar
    Nov 2007
    36
    15
    i consulted different persons and they told me that its better and it should have no issues as new vitz is also coming with this compressor as sensor based was failed. Sensor based price from toyota walton was 56k. there is no way to check this untill u install and refill gas but u can easily check clutch based easily available in bilal gang in 9k.
    Ï ïïïº ® ´¿ð´ ñ
