Results 1 to 9 of 9
Thread: Vitz giving problem on CNG
    freak_girl's Avatar
    Sep 2009
    31
    57
    Default Vitz giving problem on CNG
    I've vitz 1999 model . Few months back i started using it on petrol and almost forgot to switch it to CNG. Now when I wanted to use it on CNG it doesn start on CNG, if its start......it dies after few meters. :-/ what should I do?
    I dont have issue running it on petrol...but just in case.... :-s
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    If u dont have any issue driving it on petrol than why u bother about using cng. If u can afford petrol than remove cng its an added weight in ur car.
    " Hope for the best & Prepare for the worst. "
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    By the way it needs tune up of cng kit check air filter also.
    OptimusSS's Avatar
    Oct 2007
    26
    2,247
    make sure the fuel lines are clean and the cng kit is not bloogged up witt oil. basically get it cleaned and tuned properly.
    freak_girl's Avatar
    Sep 2009
    31
    57
    acha bhaio
    hash4u's Avatar
    May 2005
    38
    24,363
    18
    404 Post(s)
    13 Thread(s)
    13
    probably re adjustment of gas/air mixture and gas flow from T should solve the problem.
    in short take it to any cng workshop
    fyq
    fyq is offline
    fyq's Avatar
    Jan 2008
    31
    2,320
    13 Post(s)
    its a simple and common issue.just refill the cng tank to FULL, and then re-adjust its gas (from POWER-T),
    another possibility, anyone wud removed the INTAKE BLOCKING TAPE from air filter box intake, if it is removed,re tape it (upto 50% CLOSE) and adjust gas mixture from same POWER-T. it will be fiine.
    let the music play
  8. 27-07-2010, 12:48 PM
    Newbie
    Reason
    commercial advertising
  9. #8
    hassanazeem's Avatar
    Aug 2009
    30
    1,181
    2 Post(s)
    Quote Originally Posted by alrazzaqcng View Post
    pls vist AL RAZZAQ CNG services G/10/4 0300 9544670/2291224 islamabad
    Haji Sahab... Poster is in Lahore...
    My heart is a Flat 4!! 62' VW Type-1, 76' VW Sunroof SuperBeetle... To me my VolksWagen, to you yours...
  10. #9
    Faisal_RX8's Avatar
    Sep 2009
    Rawalpindi
    31
    1,098
    Quote Originally Posted by hassanazeem View Post
    haji sahab... Poster is in lahore... :d
