Results 1 to 9 of 9
Thread: abs light comes on vitz 05
    osk89's Avatar
    Jun 2009
    28
    327
    Default abs light comes on vitz 05
    hi guys i have a vitz 05 and sometimes it abs light comes on and abs stops working can some one help .? this happen very rarely. but when i turn the car off and start it again the abs works fine . what could be the problem
    Omar Khan
    irfansiddique's Avatar
    Oct 2008
    33
    1,765
    12 Post(s)
    check following things
    brake fluid,
    ABS sensors
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    You didnt get a third brake light installed recently did you? I installed a third brake light in vitz 99 once and for some odd reason, the abs light started showing up. When I disconnected the third brake light, the abs light stopped showing. Weird though
    osk89's Avatar
    Jun 2009
    28
    327
    @irfan
    the brake fluid is ful and the mechanics says the sensor is fine otherwise the abs light wouldn't turn off when you restart the car
    @owais
    no i didnt get the third brake light
    Omar Khan
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    m not an expert, but mite be due to some loose connections in the wiring which makes the ABS work...
    adeelgujjar's Avatar
    Sep 2004
    28
    34
    take the battery terminal off for a few seconds, it will reset the ecu. i had the similar problem in 99 vitz. hopefully it wont appear again
    osk89's Avatar
    Jun 2009
    28
    327
    @ waleed
    ok i will get the connections checked
    @ adeel
    I've already tried that it does'nt work
    Omar Khan
    raohamid's Avatar
    Mar 2009
    Select City
    37
    2,176
    25 Post(s)
    Have the same problem in my Mitsubishi Shogun, just turns on some times for no reason, as soon as I restart the SUV, all is well. Please let me know if you find a solution.
    Rao.
    I will miss her, that RKR. She will always be the one that got away.
    But, life goes on. From RKR to MMC. 4x4 Engaged? Team Unimog, Pakistan
    foxy_the_beast's Avatar
    Aug 2007
    Rawalpindi
    23
    340
    same thing happens with my 2000 vitz.but now i hav sold iy
    -DONT CUT ITS HANNI"S-
