hi guys i have a vitz 05 and sometimes it abs light comes on and abs stops working can some one help .? this happen very rarely. but when i turn the car off and start it again the abs works fine . what could be the problem
check following things brake fluid, ABS sensors
You didnt get a third brake light installed recently did you? I installed a third brake light in vitz 99 once and for some odd reason, the abs light started showing up. When I disconnected the third brake light, the abs light stopped showing. Weird though :S
@irfan the brake fluid is ful and the mechanics says the sensor is fine otherwise the abs light wouldn't turn off when you restart the car
@owais no i didnt get the third brake light
m not an expert, but mite be due to some loose connections in the wiring which makes the ABS work...
take the battery terminal off for a few seconds, it will reset the ecu. i had the similar problem in 99 vitz. hopefully it wont appear again
@ waleed ok i will get the connections checked
@ adeel I've already tried that it does'nt work
Have the same problem in my Mitsubishi Shogun, just turns on some times for no reason, as soon as I restart the SUV, all is well. Please let me know if you find a solution.
Rao.
same thing happens with my 2000 vitz.but now i hav sold iy:(:(
Hi guys i have vitz 2010 model , i saw its strange behaviour twice it shows abs signal n car restarts automatically n then ut workks fine can anyone tell me how to cpunterfile this issue ????
