Results 1 to 6 of 6
Thread: Vitz engine/ecu issues!
    03332648155's Avatar
    Jan 2010
    Hyderabad
    28
    425
    Unhappy Vitz engine/ecu issues!
    Hello,
    I have a Toyota Vitz with manual transmission which is troubling me alot like it takes 2-3 seconds after the accelerator is pressed to increase the rpm. Infact if more is pressed, it feels like its suffocating and engine goes off.It happens in the 1st gear only.
    Otherwise engine is soundless and very powerful.No smoke from exhaust etc.
    This is really dangerous when on a steep incline road since the rpm takes long the car goes back n hav to pull the handbrake n wait until its gained the accelerator then handbrake down n go.
    Engine has done around 90,000kms (55000 in Japan), imported by myself.And its the same even after the plug/point change and engine and cng tuning.
    N yes its happening on petrol and cng both.Do i have to remove the CAT from exhaust and spray the electronic cleaner in MAF sensor? Or its something with the ECU(I dont kno wht its function is but im told its the cars computer lol )?
    Hope someone helps.
    My Subwoofers Are My Massagers! Chronic Bass Tolerence, Induced!
    hash4u's Avatar
    May 2005
    38
    24,379
    18
    406 Post(s)
    13 Thread(s)
    13
    it seems to me like a choked catalytic converter problem
    BilalYusrat's Avatar
    Mar 2009
    Peshawar
    30
    656
    This thing unconsciously is saving a lot of fuel for you if Vitz has drive-by-wire.
    If, as you suggested, you find this dangerous.. then an easier way to quickly gain higher RPM is to hit race while pressing the clutch.
    Say to the believing men.. www.muhammadbinyusrat.com/blog/
    Skill's Avatar
    Aug 2009
    Select City
    7,885
    94 Post(s)
    40 Thread(s)
    Reading your post what comes into mind is tuning,injecter setting,tapet setting or Try enhance your fuel supply.
    https://www.facebook.com/skillgrafik
    Jan 2010
    Hyderabad
    28
    425
    @ all: Thx for the suggestion guys.
    I will go tomorrow to get the MAF cleaned up by electronic spray and tune-up (plugs n point change, tapet-settings, radiator service and coolent instead of water, air-filter change, oil n oil filter change and then car service)
    Now should i get the CAT convertor removed OR spray that Carburator cleaner in it and how to explain the mechanic about CAT in their language?
    Can it also get choked cuz i get diesel sprayed under my car on car wash? (Services station guys suggest oil(which is drained) in rainy season and diesel normally).
    AkbarGr8's Avatar
    Oct 2004
    32
    5,972
    8 Post(s)
    Please do not get diesel/oil sprayed on your cars under carriage, it harms the rubbers than safeguarding them. Get your CAT removed, take it to any decent exhaust guy, he'll know what you're talking about.
    Bees waal 4 life
  7. 18-08-2010, 01:18 PM
    Site Banned
    Reason
    Spam
