Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: vitz 2005 wobbling problem
    osk89's Avatar
    Jun 2009
    28
    327
    Default vitz 2005 wobbling problem
    hi guys i have a 2005 vitz and for a few days i have been noticing that the car wobbles at a slow speed and when i get to 50-60 kph the car doesnt wobble but the steering keeps on wobbling. can anybody tell whether its the balancing alignment problem or any other thanks in advance .
    Omar Khan
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    i think you need a wheel-balancing/alignment done.
    osk89's Avatar
    Jun 2009
    28
    327
    ok i ll take my car to get a wheel balancing and allignment as soon as i find time. thanks. but as per my knowledge if there is a balancing problem the car wobbles at high speed not at low speed. is this true ?
    Omar Khan
    s_ruhail's Avatar
    May 2009
    1,236
    36 Post(s)
    it can wobble at any speed mate.
    Get the alignment and balancing done.
    Also possible that a tyre weight fell down, causing imbalance and wobble at any speed.
    bohemian0001's Avatar
    Aug 2009
    31
    68
    Bro , i am not sure , if u need allignment ,
    as per my knowledge , Vitz got electronic stering which is lighter than hydraulic...
    i been using vitz for a year, but never been 4 allignment , neither feel like , it needs that ,,,
    better check, if there's not a major prob in that !!!
    osk89's Avatar
    Jun 2009
    28
    327
    well a few days a ago i had a little accident i hit a car in front of me. the wobbling problem started after that accident it was not major but still i will get it checked if that caused something. may be it resulted in falling of a tyre's weight .
    Omar Khan
    murtaza_murti's Avatar
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Get Alignment/Tire Rotation done as soon as possible, if that's not a problem then get your MAF Sensor and Throttle Body Cleaned and replace your Air Filter with a new one.
    - '06 Toyota Belta 1.0L X - '68 VW Beetle 1300 DP - '89 Nissan B12 E16
    osk89's Avatar
    Jun 2009
    28
    327
    what part throttle body, air filter and maf sensor play in wobbling ??
    Omar Khan
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Wobbling on slow speed or idle, means their is probably dirty/un-wanted particles in your throttle body or MAF sensor which are choking the air that is trying to enter the engine.
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Get your Camber's and axle joint's checked aswell.
    osk89's Avatar
    Jun 2009
    28
    327
    thanks murtaza i ll get them checked as soon as possible
    Omar Khan
  12. #12
    osk89's Avatar
    Jun 2009
    28
    327
    hey guys i got my car checked guess what it wasnt allignment problem i dont know how but the tyre got deformed thats why car was wobbling . now i have to buy a new tyre
    Omar Khan
  13. #13
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Your camber off-set wasn't in it's proper angle, the angle on which the tire was sitting caused the wobbling, good to hear you got it checked.
  14. #14
    HAshims's Avatar
    Aug 2004
    25
    4,886
    39 Post(s)
    3 Thread(s)
    sometimes my vitz wobbles too when i press the accelerator too hard on D. It has no alignment type problem to be exact it vibrates a little not wobbles.
    Honda Civic 99 EK Hatch / Honda Integra 92 DA Coupe
    RIP Adil( @AridSoul)
  15. #15
    129
    129 is offline
    129's Avatar
    Jul 2007
    28
    460
    3 Post(s)
    @poster
    i have used 2006 vitz for three years .If u r talking about shake which car usually makes when its stationary its due to its three cylinder engin and its normal so nothing to worry about . Rest if u know about the my mentioned problem and you are facing some different wobble then i ll suggest you to get your car checked from toyota dealer mostly prefered toyota walton motors as they were the ones who use to maintain my vitz and trust me i never had a single glinch of problem in three years and the shaking problem of my car was also solved to a lot of extent as compared to other cars of its model . I ll suggest you to get your checked from Basit available at Toyota Walton motors
  16. #16
    humayunahsan's Avatar
    Feb 2005
    35
    45
    hey Allm i have already posted this problem in some other thread, i have just bought a vitz a week ago, it make a funny belt slipping like noise on pick up. How and where to get it fixed ?
  17. #17
    osk89's Avatar
    Jun 2009
    28
    327
    @ murtaza
    i dont know whats the chamber but the problem was the tyre the rubber deformed somhow so thats why it was wobling. but still thanks for the interest i appreciate it.
    @ 129
    well the problem u r talking about is vibration not wobbling well i have that too i ll go to the suggested workshop. can u tell me what the mechanic did to eliminate vibration in ur car ?? actually i converted my car on cng which ruined my engine now the mechanic says the vibration is caused because valves problem or somthing like that.
    @humayunahsan
    u can go to the mechanic 129 suggested or u can go to rehman workshop he is near qanchi his no. is 03024243455 you can ask him the address. i go to him as he has all the spare parts of vitz and has gud knowledge of the car too
    Omar Khan
  18. #18
    jawaadirfan's Avatar
    Mar 2011
    245
    check your petrol pump
  19. #19
    Mar 2011
    245
    i have also vitz 2007 sometime its vibrate like haming in car i go to mechanic he tells me that the problem is of petrol pump
  20. #20
    chinyoti's Avatar
    Sep 2005
    27
    11,965
    5
    108 Post(s)
    5 Thread(s)
    The wobling steering can be due a "uneven shaped tire"
    or some serius issue with the suspension of the car.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
