Results 1 to 3 of 3
Thread: vitz 2006 AC .. Where to buy
    shiraz_kaka's Avatar
    Dec 2006
    Abu Dhabi
    30
    281
    3 Thread(s)
    Default vitz 2006 AC .. Where to buy
    Well after some long tiring trips to a lot of AC workshops i finally found out that my cars compressor needs to be replaced, bec the compressor stops working for 10 min after every 20 min of operation.
    I need help where to get the compressor from. Is this a persisten problem in the new vitz ?
    Secondly if i buy from shershah ... is there any shop there which can give me some kind of guranteee whether it will work and doesnt have the same issue and its not repaired
    Thanks
    VTEC.. THE REPLACEMENT FOR DISPLACEMENT
    affan555's Avatar
    Mar 2010
    Shenyang
    26
    893
    3 Post(s)
    u mean trip ho jata hai?
    authentic's Avatar
    Sep 2005
    46
    35
    change your compressor . Replace it with vitz 2004 model. Also you have to change the belt. It will be perfect.
Tags for this Thread
