Results 1 to 4 of 4
Thread: How to install air intake in yaris ?
    Attitude_Problem's Avatar
    Mar 2006
    30
    93
    Default How to install air intake in yaris ?
    Dear Experts
    I;ve 1.0 yaris, the problem im facing is that when i remove the VVTI box from the throttle body to install air intake with pipe so the car does not starts due to maf sensor problem so kindly suggest me what should i do? presently im running intake on that vvti box.
    IF I GET EXACTLY PIPE OF THROTTLE BODY SIZE AND I MAKE SOME PLACE FOR THE MAF SENSOR ON THAT PIPE SO WILL IT WORK?
    I'M IN NEED OF URGENT HELP.
    THANKs
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    I Did it a while back custom made check below thread
    https://www.pakwheels.com/forums/d-i...71700-wrd-vitz
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    Mar 2006
    30
    93
    thx wasay ive seen the thread but where to put the maf?
    Nov 2006
    29
    4,959
    12 Post(s)
    well it can be clearly seen in all setups
