Results 1 to 12 of 12
Thread: Problem with Vitz
    atta123's Avatar
    Dec 2010
    9
    Question Problem with Vitz
    I own vitz 2001 model.
    The problem is whenever I turn of the O/D which lets the car to be driven on 4th gear. Whenever the car shifts to 4th gear it doesn't accelerate , it keeps on decelerating and shifts back to 3rd gear.
    What could be the problem?
    Please Help Asap.
    Thanks
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    tranny issue
    atta123's Avatar
    Dec 2010
    9
    What should be done? My friend told me that it is a throttle issue
    REDZDEVIL's Avatar
    Jul 2008
    28
    3,489
    How does da car perform's on da normal gears..!
    atta123's Avatar
    Dec 2010
    9
    Totally fine , but when it shifts to 4th gear , it doesn't pick up any speed. And if I accelerate too hard , it shifts back to 3rd gear with a jerk.
    REDZDEVIL's Avatar
    Jul 2008
    28
    3,489
    Mate it cant be something related to the throttle body fo sure get ur Tranny checked..!
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by atta123 View Post
    4th is overdrive and wont let you accelerate fast, if you floor the accelerator fully it will KICKDOWN to 3rd and accelerate the car fast and shift to 4th once you let off. If you press the O/D off button your transmission will not engage 4th (overdrive gear). The 4th in an Auto is like 5th in a normal manual.
    what you said sounds completely normal
    btw using cng?
    another point to check is that your throttle sensor is calibrated to your throttle lever perfectly, our ullu ke patthay mechanics love to fiddle with the throttle stop screw throwing the sensor out of calibration.
    memad's Avatar
    Nov 2010
    39
    5,503
    180 Post(s)
    btw using cng?
    @Xulfiqar
    The throttle wire in my car is a little loose, like a play of 2 cm so tightening it will cause the Thorttle Position sensor misaligned let me knoe so that I can proceed with the DIY, there is no problem in gaining the speed now but I feel to tight the wire.
    atta123's Avatar
    Dec 2010
    9
    btw using cng?
    Thanks for the detailed reply
    actually when it shifts to 4th gear even if I don't push the accelerator too hard it will decelerate no matter what , it feels like engine has lost all the power .. and driving while o/d off on motorway with the speed of 120 km/h , the engine cries.
    I don't have much knowledge about cars technicality .. can you suggest what to do in simple manner?
    Thanks
    atta123's Avatar
    Dec 2010
    9
    no one?
    versatilegenious's Avatar
    Jul 2009
    24
    7,661
    12 Post(s)
    2 Thread(s)
    Quote Originally Posted by iLLDuDe786 View Post
    tranny issue
    +1
  12. #12
    Baachaa's Avatar
    Dec 2010
    Mardan
    14
    bai saab ye engine intepelo hogaya hai. is engine ko shaga karo aor 1.8 litre regetum engine lagao wo bohot bomo chakatas hota hai ..
