Results 1 to 9 of 9
Thread: removing the catalytic converter in vitz
    fso
    fso is offline
    fso's Avatar
    Jul 2007
    Faisalabad
    32
    1,400
    6 Post(s)
    Default removing the catalytic converter in vitz
    Mod Edit: Thread moved to correct section.
    guys i bought a vitz 2005 new shape i just wanted to know how do i know if cat is removed from my vitz and also what should i tell the silencer mechanic because they might not know what im talking about should i take it to toyota motors also what if i put an exhaust system in it ....
    r3act
    iLLDuDe786's Avatar
    Feb 2009
    New York City
    11,213
    if ur not facing any sort of problem, then u shud not do it
    you can take ur car to toyota 3s and get the whole check up
    MrNiceGuy's Avatar
    Aug 2006
    Peshawar
    35
    2,242
    Well brother Removing Catalytic converter is not a good option, as it is useful stuff.
    Wear Seat Belts. Your Family Loves You.
    fso
    fso is offline
    fso's Avatar
    Jul 2007
    Faisalabad
    32
    1,400
    6 Post(s)
    ^^ thanks man but the thing is that i dont know about the pick as i used to have civic 2k5 exi with k 20a engine so im not sure about the pick but the car dosnt give any black smoke as before buying i checked few other vitz they were giving black smoke and few of them had louder engines like a diseal and one was not even picking race as i was giving it in idle speed but this one seems to be fine no smoke quiter engine ...
    r3act
    fso
    fso is offline
    fso's Avatar
    Jul 2007
    Faisalabad
    32
    1,400
    6 Post(s)
    and also i used to fill my civic with shell unleaded fuel but some told me it was bad for performance and then i started using total's fuel and the performance did increase i was reading lot of threads and saw that should use unleaded fuel and i think shell is the only one who sells them and i only noticed them havnt notice others so should i use shell or go with caltex or totals petrol ????
    r3act
    fso
    fso is offline
    fso's Avatar
    Jul 2007
    Faisalabad
    32
    1,400
    6 Post(s)
    r3act
    sameer3389's Avatar
    Apr 2005
    Faisalabad
    33
    1,973
    34 Post(s)
    2 Thread(s)
    dont remove it
    it makes the car greener and fuel efficent too its good to have it rather then removing it
    Site Banned Follow
    aghajaved's Avatar
    Aug 2008
    44
    41
    Quote Originally Posted by fso View Post
    catalytic converter is a cylindrically shaped piece underneath your car in the middle of your exhaust pipe. it can be seen by slipping under neath the car or by lifting it up easily. any workshop can tell you if it is their or is removed. its that simple
    stingray's Avatar
    May 2005
    Peshawar
    37
    859
    5 Post(s)
    In the new shape vitz its not under the car...its right at the start of the exhaust system just under the headers (thats the main CAT) the 2nd cat is near ur tail pipe n it isnt usually choked...the one near the engine is after being run in Pakistan for around 30k km. so it depends whether ur car has been run 30k km in Pak or not.
    I used to own a 06 vitz n i also got my cat removed but later on someone told me a better solution which i wish i shuda tried first before removing it....basically removal means breaking it (its ceramic) so thers no goin back...if u wana install a new system its gonna cost u around 25 thousand so dont think on those lines.
    What i wish i shuda tried first was to clean it....yes it can be to some extent....have its whole assembly taken out at a workshop and drip small amounts of sweep mixed with a bit of water from the top...let it drip thru ur cat onto the ground....keep doin this with small amounts of sweep mixed with water. Do this for about an hour. Then let the Cat dry up in sun....u'll see its gonna be clean of most of its lead accumulation. Just take care u dont touch the sweep with the side walls inside the assembly...coz the cat is attached with the side walls thru a cotton mesh n that will get damaged....so be very specific to drop that acid only on the middle part of that cat not the side walls.
    cheers.
