Results 1 to 5 of 5
Thread: Vitz manual gear
    BASITNAMDAR's Avatar
    Mar 2009
    46
    8
    Default Vitz manual gear
    AoA, I have a manual 2001 vitz which was working great till i got my car serviced 3 days back. Firstly it started giving JHATKAS which were rectified by cleaning the spark plugs. Than there is this new problem That my car gear box is quite smooth in idle. but as soon as I start to run my car the gear gets quite hard i.e. it feels as if something is stopping it from changing gear. I also got my gear oil changed. Please help
    Skill's Avatar
    Aug 2009
    Select City
    7,885
    94 Post(s)
    40 Thread(s)
    The hardness remains same after some travelling?
    https://www.facebook.com/skillgrafik
    Mar 2009
    46
    8
    yeah usually hardness remains esp 1st 2 gears. I recently got oil change is it because of improper placement of seal of gear oil after refilling??
    Skill's Avatar
    Aug 2009
    Select City
    7,885
    94 Post(s)
    40 Thread(s)
    Quote Originally Posted by BASITNAMDAR View Post
    what type of seal you are thinking about?
    Gear oil changing doesnot involve any associated seal to be messed with.
    The only ring leather seal,and thats too becuase of faulty tranmission case drain nut.
    Problem lay some where in gear selector.(my judgement)
    automaster's Avatar
    Nov 2008
    185
    fill 75w85 transmation oil in gear it will healup
