Results 1 to 9 of 9
Thread: Vitz vvti Engine
    Spy3D's Avatar
    Nov 2007
    35
    40
    Exclamation Vitz vvti Engine
    Salam,
    Few days ago my vitz 2003 oil pump stopped working and me being unaware of that continued to drive the car which affected the engine and now the mechanic is saying the engine will have to be opened and ring-pistons might need to be changed.. but i have heard many times that after the engine has been opened the car's performance is affected and originality is lost.
    So now i am thinking of replacing the engine, does anyone have any idea how much vitz 2003 vvti engine may cost? and from where should i buy it?
    Thanks
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Shershah is the place but i don't have any idea about the price
    ~ Be a responsible citizen and always drive safely ~
    versatilegenious's Avatar
    Jul 2009
    24
    7,661
    12 Post(s)
    2 Thread(s)
    performance is only affected if u install 2no parts and worked by ustaad's qabil Shaagirds
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Oil Pump Stopped working and oil light don't even goes up ???? + crank survives...?? piston rings done???? i don't get it
    what kind of pump failure was that.....!!
    if its done then you need long block and that gonna cost you not less than atleast 35-40k...!!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    Spy3D's Avatar
    Nov 2007
    35
    40
    i will know more in detail when the engine is opened tomorrow.
    I somehow miss-understood the oil light when it got lit and just after few km the car stopped and some noise started coming from the engine when i tried to accelerate. Yes i know it was my fault that i didnt took it seriously earlier :/
    baajwa's Avatar
    Nov 2009
    36
    92
    no performance issue man, first check to what extent engine is effected,due to heat up if only gasket,pistons are affected n rest components are safe(block,crank,cam etc) then there is no need for engine swap. get a good mechanic reapir engine with genuine parts n there u go.Allah Almighty help u
  7. 31-01-2011, 11:55 PM
    PakWheeler
    Reason
    Duplicate
  8. #7
    Spy3D's Avatar
    Nov 2007
    35
    40
    thanks and what about resale value of the car, how much is it affected when engine is opened?
  9. #8
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    bro, if i were u, honestly, i wud take it as a blessing lolz..why ? i wud straight away go for a bolt on bolt swap....just replace this 1SZ with a 2NZ-FE (1.3 vvti) and enjoy ur ride...cause if u replace the engine, the documents are to be changed anyways...so why not to have a better engine...and u wud LOVE ur car like anything
  10. #9
    juadjee's Avatar
    Dec 2008
    30
    1,367
    12 Post(s)
    For an estimate of the engine prices you can raise a query on the thread called 'engine prices in peshawar'
    The pain of war cannot exceed the woe of aftermath.
