Results 1 to 17 of 17
Thread: vitz engine died...need help
    nomi01's Avatar
    Dec 2005
    Rawalpindi
    30
    189
    Default vitz engine died...need help
    my friend has a 2005 model vitz...the car developed starting problem in morning nd the battery was also weak..we jump started the car nd rest of the day it started easily..the next morning it refused to start even on jump starting..after struggling for whole day,no fault was found..fuel pump,injectors,spark..evrything is fine..it cranks but doestnt start...cheked obd2 codes nd evrything is clear....the mechanic says it has lost compression nd needs a new assembly(??)
    now i cant understand how all of sudden it can loose compression..mechanic says pressure rings are out(??)car is on petrol nd engine nd it didnt consume oil...
    need help from experts asap
    tayyabbaig's Avatar
    Nov 2008
    Oslo
    34
    2,706
    3 Post(s)
    Have u checked the timing belt??
    nomi01's Avatar
    Dec 2005
    Rawalpindi
    30
    189
    no...but wud chek it 2morow
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    do a compression test then consider the options - engines do not lose compression overnight. A compression tester can be bought for Rs 1000 - much cheaper than swapping or overhauling an engine.
    secondly check the injectors with a noid light or something similar that they are pulsing and check the coils that a spark event is actually taking place. The symptoms you mention usually lead to a bad crankshaft position sensor making the engine go completely dead - no injector pulse, no spark. OR a bad MAF - in this case the engine should start but die as soon as you leave the key
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by tayyabbaig View Post
    his car uses a chain
    nomi01's Avatar
    Dec 2005
    Rawalpindi
    30
    189
    @xulfiqar: fuel nd ignition both r present..so my guess is a bad maf sensor.
    bluespark's Avatar
    Oct 2005
    Dublin
    34
    1,244
    few questions to answer.
    Was car wating oil before?
    How was the pick yesterday when you jump start it?
    Was any smoke from silencer prior to this problem.?
    Whats the milage?
    I think your mechanic has put a reasonable guess, and yes cars can loose compression realtively suddenly. Avoid too many diagnostics, and if answer of above questions are in faour of weak engine, then you have the answer of your problem.
    Das Auto, Der Golf!
    nomi01's Avatar
    Dec 2005
    Rawalpindi
    30
    189
    @bluespark: car is on petrol ,mileage 80k..it had normal pick when last drivern..no engine oil consumption..no oil burning blue smoke...engine was in perfect condition..a weak engine which has low compression eats lot of oil which is not da case here
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    do a compression test to further finalize your diagnosis - sudden compression loss is usually due to burnt valves - happens in these type of toyota engines as the valve lifters are completely solid with no adjustment
    more to confirm - a dead engines starter will not sound normal - it will more sound like a juicer rather than a starter motor
    tayyabbaig's Avatar
    Nov 2008
    Oslo
    34
    2,706
    3 Post(s)
    Must check crank sensor as mentioned by @Xulfiqar, if possible swap it with anyother vitz if some friend has.
    razapower's Avatar
    Nov 2004
    40
    403
    Take it to Toyota or Nazir Autos.
    It must be a problem with the sensors. Dont jump to engine change so quickly.
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    if you have positive spark and fuel injector pulse you have a working crank sensor, your problem lies elsewhere
  13. #13
    Ahkhan89's Avatar
    Jul 2010
    86
    8
    2 Post(s)
    check head gaskit, may b car overheated on last drive.........
  14. #14
    a4awais's Avatar
    Jun 2005
    35
    1,287
    these engines can survive for more than 200k km. consult with real professionals to locate your problem.
    http://www.facebook.com/jadoon.awais
  15. #15
    aliusman420's Avatar
    Nov 2006
    6,935
    97 Post(s)
    2 Thread(s)
    did you check the battery?
    8th Gen Mitsubishi Lancer 1.3 GLX 2006; 3rd Gen Toyota Prius 1.8 S-Touring 2010; 11th Gen Toyota Corolla 1.3 GLi AT 2014.
  16. #16
    sh4dow's Avatar
    Mar 2011
    Calgary
    42
    just chek your battry power io think bettry is weak....... weak gravity
    *''*Someone has to fix the problems*''*
  17. #17
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    @poster first of all work on the earth wiring if its loose or not properly connected.
    then look for your self is it weak?or needs a cleanup?
    to me these two thing might b the possibility of this problem.
    @tayyabbaig when timing is out car does not starts at any case easily but the poster has mentioned he did it by a jump start so it does not seems as a timing problem.
    ''Peace is an unstable equilibrium,that can only be preserved by acknowledged supremacy and...equal power.'' ''We give up the fort when there is not a man left to defend it.''
