Results 1 to 12 of 12
Thread: shaking vitz
    fg
    fg is offline
    fg's Avatar
    Jan 2007
    Peshawar
    36
    69
    Default shaking vitz
    selam i ve 99 vitz vitz 110k milage and sometimes when i shift to drive n press the breake it s vibrating what may be the problem coz of engine or gearbox d u plz help me if u have any expnc
    everon's Avatar
    Aug 2010
    31
    51
    its ABS?
    usarwar's Avatar
    Aug 2006
    30
    993
    check the clutch plate and transmission. this is sumthin serious... if it vibrates during ride it can b a suspension issur too...
    fg
    fg is offline
    fg's Avatar
    Jan 2007
    Peshawar
    36
    69
    thanx for ur interest
    yes ABS
    it s vibrating only when my foot is on the breake in gear is D mode
    in this time may it be seriouz cn u expln more plz
    scorpion80's Avatar
    May 2007
    36
    4,320
    11 Post(s)
    wheel balancing...
    suspension check up
    fg
    fg is offline
    fg's Avatar
    Jan 2007
    Peshawar
    36
    69
    i hope not engine problem
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    vibrating in D whilst stationary is either - low revs or a bad Idle air control valve. Get that sorted - However it is supposed to vibrate but only gently
    fg
    fg is offline
    fg's Avatar
    Jan 2007
    Peshawar
    36
    69
    thnks soo much
    chinyoti's Avatar
    Sep 2005
    27
    11,965
    5
    108 Post(s)
    5 Thread(s)
    how to get it sorted?
    increase rpm?
    bad spark plugs?
    Or a OBD scanner would figure it out?
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    umaslam's Avatar
    Mar 2007
    34
    36
    Asalam O ALikum Pakwheelers,
    Recently bougth vitz 2003. Its a fine car but with some issues, as all 2nd hand cars are prone to issues.
    Problems:
    1. Before starting the car. when I switch on the ignition there is a wierd sound it goes like....teeeeee(a horn sounding low) or if some wire thing gets earth. It goes away when I start the car and run engine for a while. Cannot figure it out please assist?
    2. I feel that when the car goes into 3rd gear(Auto Transmission) it loses its pick drasticly does not accelerate like in 1st or 2nd gears. Please assist?
    Should I take my car to TOYOTA for general check up and diagnostics? Please sussgest.
    Wiaiting for your kind response.
    shaizy007's Avatar
    Dec 2008
    Faisalabad
    35
    959
    its not engin problem, its break issue. is ke taway ko kharadiay se repair karwao.
  12. #12
    saint272's Avatar
    Mar 2007
    Virginia
    29
    108
    if the car is shaking while your breaking that chances are that it could be that your rotors need to be resurfaced or you need new ones completely. if it does that while idling you might want to think about getting a tune up.
    I gota new "VIBE....kinda like voodoo...YOU do what I say and I'LL do what I wanna do!!!!
