Results 1 to 12 of 12
Thread: Help regarding swap in vitz
    Attitude_Problem's Avatar
    Mar 2006
    30
    93
    Default Help regarding swap in vitz
    Hello experts
    i am planning to install assembly of 1nzfe (1.5) in vitz, i need to confirm that will it come bolt on ? secondly will the ecu and gear remain same or not ?
    and same case for 2szfe, will the ecu and gear remain same or not
    reply soon
    thanks
    iffe's Avatar
    Feb 2004
    34
    1,031
    8 Post(s)
    originally 3szfe comes in vits
    but for 1 nz or 3sz u have to change every thing from gear axcel and every thing
    He who hesitates is not only lost but miles away from the next exit
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    which model you have
    yes its bolt on
    MOTOR MANIACS ... An automotive service and repair workshop
    https://www.facebook.com/pages/Motor-Maniacs/721830141231922
    Mar 2006
    30
    93
    dude 1szfe comes original not 3sz
    ive 2000
    tayyabbaig's Avatar
    Nov 2008
    Oslo
    34
    2,706
    3 Post(s)
    Bolt on.
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    1 szfe hota hai vitz mey but dats nt a bolt on swap cz as per my knowledge vitz in 1.5 is awd. correct me if m wrong...
    2c
    2c is offline
    2c's Avatar
    Aug 2007
    Sialkot
    12,284
    9 Post(s)
    MODEdit: 2c stay away from pro forums if you can not contribute anything good
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    friend imported front cut
    did 2 vitz swap in islamabad
    1.5 bolt complete front cut of vitz
    from engine...ecu...susp...wiring ..gear box....brake rotors..even abs
    works great
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    Quote Originally Posted by iffe View Post
    its 1sz-fe....3szfe is 1500cc which comes in terios kid..not vitz
    and 1nz id the production engine in vitz ....so its clear which 1 will fit properly
    rozzzzz's Avatar
    Oct 2005
    21,925
    12
    140 Post(s)
    5 Thread(s)
    Quote Originally Posted by Attitude_Problem View Post
    Hello experts
    reply soon
    thanks
    @2szfe
    Am not sure but i think this engine came in upper model after 2005...not in yr vitz
    and they done share the same mount positions
    #regarding the gear box....yes u have to chnage in every case..even if some gear fits another engine
    you may get different gear rations...
    and you may experience a sliped clutch
    2c
    2c is offline
    2c's Avatar
    Aug 2007
    Sialkot
    12,284
    9 Post(s)
    Quote Originally Posted by 2c View Post
    yes sir
  12. #12
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    2szfe will be direct boltonn even on stock wiring loom just have to replace ecu other then engine assembly wth gear etc.
    for 1nzfe trans mod will hav to be bugged and wiring and axcles but thts also not much headache
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
