Results 1 to 17 of 17
Thread: Vitz 2001 Questions?
    cyberdera's Avatar
    Mar 2011
    73
    2 Post(s)
    Default Vitz 2001 Questions?
    Hello All,
    I am a bit new here so please allow me tha audacity to do as much mistakes as possible . Ok i got my Vitz 2001 and this is my first car so ofcourse im not very good at anything. it was all fine for 2 months and i never touched 100 but one day jawani ke josh mein i touched 110 and suddenly the engline light came on. I thought it maybe a fuel problem as i had gotten my tank filled after it was near empty. I turned the car off and when i turned it back on it was gone. but after every 20 Km or so the light turns on again. I am really worried. I tried getting High octane injected in my tank to improve fuel quality but it was the same .. 20 km or so and the light comes on.
    Please tell me what the problem could be. I dont have CNG. is it the MAF sensor or can it be something big. I am in Islamabad where should i take my car to and be sure that the problem will be figured out.
    Thanks a lot for any help
    http://cyberdera.com/pakistan/djuice-khamoshi-ka-boycott-and-the-sad-state-of-our-society-and-its-influencers/
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    No need to worry about the engine light. it appears in all those vitzes n platzes which have their catalytic converter removed.
    cyberdera's Avatar
    Mar 2011
    73
    2 Post(s)
    Quote Originally Posted by Retaliator View Post
    Thanks for the reply Retaliator .. but it never came on for the last 2 months. now its coming on after every 20 Km. I didnt remove the Cat Converter myself. if it is removed it must have been taken off by the last owner. i mean till i had not touched that 110 it never came on no matter how long i drove it for. what could be the case ???
    Adeels1's Avatar
    Apr 2011
    Renala khurd
    324
    2 Post(s)
    Sorry bross, u need to describe that if any light is coming , then whats the indication, one desi jugar= take ur car to any good electriction and tell him to remove the fuses which have connection with that light, in that way u can trace the root of ur light ,
    and repeat step again and again( i mean remove 1 fuse chek, then fix it , now 2 fuse and chk,step by step)
    At the end check the manual of ur car.( last solution )
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Simplest way to diagnose the CEL would be to goto a toyota stealership, they'll charge about 600 rupees and check it for you. Stay close to them, ask them to let you see whats on the screen and after you're done - report back here.
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    get the throttle cleaned, i used 99 vitz more than two year, even not a single problem on lahore to karachi routes
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    Quote Originally Posted by cyberdera View Post
    I had same experience with my father's platz which we r running on petrol. after removing the CC nothing happend for quite some time. then all of a sudden it started turning on after a highway trip. been to toyota several times and the problem has not been solved. so i am guessing that u r experiencing the same thing.
    the reason is simple. after the removal of CC the sensor on the exhaust gives abnormal signal due to change in pressure n flow conditions.
    well there can be any other reason. u shud get ur car checked by the hand held tester from toyota.
    cyberdera's Avatar
    Mar 2011
    73
    2 Post(s)
    Man these japanese cars .. i havent seen any change in engine performance or anything else. Just very worried i dont want to end up with something big with the engine. Will get the MAF sensor, throttle body and stuff cleaned. lets see, also will get the Cat converter checked if it is there or not, cause the person from whom i bought was an old guy he didnt know much himself. Whatever his son wanted to do with it he did and now hes abroad
    pistonhead's Avatar
    Dec 2009
    86
    1,444
    24 Post(s)
    try resetting the ECU by taking off the battery terminals for about a couple of minutes, it might work.
    Quis custodiet ipsos custodes?
    cyberdera's Avatar
    Mar 2011
    73
    2 Post(s)
    Quote Originally Posted by pistonhead View Post
    wouldnt that work if it was constant. because it comes only after 20 km of drive. and it started appearing after my first 110 ... could it be the MAF sensor
    cyberdera's Avatar
    Mar 2011
    73
    2 Post(s)
    also can you please tell me the best place for getting my vitz checked in Islamabad. Some mechanic who would understand all this without a problem
  12. #12
    Elien's Avatar
    Nov 2010
    24
    812
    aray bhai light to kia batao indication de rahi hai post da pic?
  13. #13
    cyberdera's Avatar
    Mar 2011
    73
    2 Post(s)
    Quote Originally Posted by Elien View Post
    its the engine light. Yellow colored. its not blinking or anything just static and it comes on after every 20 km or so
  14. #14
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    Quote Originally Posted by syncview View Post
    +1
    or u disconnect the batery n reconnect it ,c if that helps,
    this can be due to the maf but as sync said best way is to go to toyota dealership n theyll go a complete it check n the problem wil be figured out in no time
    www.facebook.com/performancepartslahore
  15. #15
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    +1
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
  16. #16
    cyberdera's Avatar
    Mar 2011
    73
    2 Post(s)
    Thankyou all for the help will be visiting toyota service center this saturday
  17. #17
    Nov 2006
    29
    4,959
    12 Post(s)
    i was facing same problem did 1 thing though a crazy experiment :p.remove the air filter n let the housing open.take ur car to open road gave it 5 6 runs wth full accelration like u should acheive 100+ when u notice the speedo changing 1st gear at 54 n 2nd at 98 means uv achieved ur target
