Results 1 to 5 of 5
Thread: Vitz-99 race problem/ mechanic in faislabad
    f_m
    f_m is offline
    f_m's Avatar
    Dec 2008
    36
    56
    Default Vitz-99 race problem/ mechanic in faislabad
    AOA.
    I have 99 model. It gets accelerated automatically and gets off on low speed especially in reverse gear..brake also becomes hard at times. I got the race adjusted but it did not work.some one said the problem is with the throttle body and change it. But i want a good diagnostic to proceed with.
    can some one suggest a soloution or a mechanic in Faislabad to get my vitz checked.
    <!-- / message -->
    shaafkhurram's Avatar
    Dec 2010
    60
    i guess ur throttle body needs a cleanup..... get it done from a expert mechanic...
    coz changing a throttle body .. getting a new 1 wud be expensive.... and and and... but if still problem exsisits. den get 1 frm bilal gunj i guess dats da 1 in lahore..
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,960
    12 Post(s)
    petrol or cng?
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    spray some carby cleaner in the IACV port
    f_m
    f_m is offline
    f_m's Avatar
    Dec 2008
    36
    56
    both on cng and petrol.
    which is the IACV port?
