Results 1 to 10 of 10
Thread: vitz 2005 - abs indicator
    chiliblast's Avatar
    Jul 2007
    Wah cantt
    35
    9
    Default vitz 2005 - abs indicator
    Hi.
    I got vitz 2005 a month earlier. Everything is ok, but i have notices when i switch on, i dont see ABS indicator. What is the problem?
    Also i put new speakers, and the technician attached wired with the tape.
    Thanks
    afnan_88's Avatar
    Jun 2005
    Dubai
    28
    2,405
    8 Post(s)
    check ur brake li8s , both r working or not
    hamza_xeg's Avatar
    Aug 2009
    Abbotabad
    20
    8,788
    94 Post(s)
    8 Thread(s)
    Thumbs up
    Quote Originally Posted by afnan_88 View Post
    +1
    The men are back. @TGT.
    Khan_Saab's Avatar
    Apr 2010
    Peshawar
    24
    331
    11 Post(s)
    hey may i know whats the relationship of brake Lights with ABS Module ??
    i'm facing the same problem & i think one of my brake light is fuse, don't worry i will replace it soon but it doesn't looks like it gonna solve the ABS problem,
    to varify it removed the ABS Fuse to see the ABS light but still there is no light, i think someone had removed the ABS light wires from ABS Computer in JAPAN in order to hide ABS problems as its expensive to repair. . .
    aamirq's Avatar
    Oct 2006
    31
    1,726
    26 Post(s)
    simply check ur abs by braking hard and trying to cut the steering! if ur wheels lock up that means there is a problem wit ur abs! or try driving on a road with bajri on it and try braking u shud hear THAG THAG THAG sounds frm the brakes that means abs is working!
    "The world ain't all sunshine and rainbows. It's a very ruff, mean place, and no matter how tuff you think you are, it will always bring you to your knees and keep you there permanently if you let it.You or nobody ain't never gonna hit as hard as life, but it ain't about how hard you hit, it's about how hard you can get hit and keep moving forward, how much you can take and keep moving forward. If you know what you're worth, go out and get what you're worth, but you gotta be willing to take the hit."
    - Sylvester Stallone
    afnan_88's Avatar
    Jun 2005
    Dubai
    28
    2,405
    8 Post(s)
    Quote Originally Posted by Khan_Saab View Post
    i had the issue in my jap alto wher my abs was not working , reset the ecu but didn`t work , there was a check engine light too so the auto electrician adviced me to check the car on computer , when the car was diagnosed , i was surprised when the error was , check brake blubs , pressed the brake bulbs n both were fused , got new bulb n problem was solved immediately after that
    murtaza_murti's Avatar
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Quote Originally Posted by chiliblast View Post
    Hi.
    Thanks
    When you apply your brakes, does the brake pedal feel really really soft? Do you find the vehicle difficult to stop?
    - '06 Toyota Belta 1.0L X - '68 VW Beetle 1300 DP - '89 Nissan B12 E16
    chiliblast's Avatar
    Jul 2007
    Wah cantt
    35
    9
    No, brake is ok
    chiliblast's Avatar
    Jul 2007
    Wah cantt
    35
    9
    i have noticed, abs light gets on when i switch on sometimes, and sometimes not
    siliconbwp's Avatar
    Feb 2015
    Bahawalpur
    28
    9
    same problem with me any solution?
