Results 1 to 2 of 2
Thread: Replace coolant? Toyota Vitz 04
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Default Replace coolant? Toyota Vitz 04
    Hello,
    I noticed that the colour of the coolant is now a very light colour as compared to dark red in the white plastic tank. I am using Toyota Long Life coolant.
    Should I replace all the coolant and put in fresh one? How much coolant and water should I mix if I am using Toyota Long Life Coolant?
    Thanks
    Tyrone
    lovesleeping's Avatar
    May 2010
    Hyderabad
    1,468
    if the colant has been in the radator for more than three years then replace it
    Honda Boys..Powered by R18!
