Results 1 to 16 of 16
Thread: help Needed For Vitz!!!!!!!
    bilalnoor1987's Avatar
    Apr 2011
    Select City
    210
    13 Post(s)
    Default help Needed For Vitz!!!!!!!
    hello Friends!
    I have Bought 2008 Vitz 8 Months Back.
    it was running very smoothly ..
    but from last few months i am facing some of the issues in it
    > my car is giving me the mileage of 9km/l
    > in D mode It start shivering and became normal in N mode
    > on slow rpm i mean b/w 2-3 when i reach the speed of atmost 30 a strange voice like gaar gaar came from engine which runs away if the pedal is pushed a little harder i mean if i increase the rpm
    Things That HAve been Done Till Now...
    hi-octane mixed 50%
    petrol cleaning agent of company liqy moli name i dont remember has been used also bcoz one of my friend said that due to dirty petrol some times tank main kachra aa jaata hai and to remove kachra you have to use that cleaning agent
    changed the engine oil with mobil
    changed air filter and oil filter
    changed plugs with geninue iridum toyota plugs that cost me 2800
    thorotle body cleaned
    Gear oil changed
    one of my friend said me to remove CAT from the car which i didnt do due to the increament in pollution.
    i went to toyota garden they said we wwill charge 3500 for cleaning CAT which i know is very much
    please some one with pictures guide me how to clean the CAT ...
    did the cleaning of CAT will result in solving my issues...?
    now i need experts help to make my car smooth and comfortable free of shivering and also how to increase the petrol mileage as my car was giving me above 13
    Apr 2011
    Select City
    210
    13 Post(s)
    not a single reply
    where are the experts of vitz gone????????????????????????
    TTQcarguy's Avatar
    May 2011
    im not pretending to be an expert but i also owned a 2009 vitz and experienced the same problem. it ran fine for about 5000 kms (it was a fresh import) and then that really annoying braaaah kicked in and it started to knock as well sometimes. I used regular fuel. I eventually sold it off but what i can suggest is using 100% high octane as i think the problem is related to inefficient combustion as supplemented by the knocking. so try it out for a few fillups and if that doesnt work, best live with it i ran mine for 60000 kms with the noise so i dont think its a big deal.
    Hesab_Magsi's Avatar
    Aug 2010
    Quetta
    26
    1,739
    31 Post(s)
    Knocking has been a big issue with the present shape of vitz.tried 100% hi-octane aswell but no luck :|
    Aug 2010
    Quetta
    26
    1,739
    31 Post(s)
    remember ,if u remove CAT ur car will sound very weird,like ratling sound from silencer.for shivering,try changing plugs as it helped me.
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Remedy for high consumption and vibrating engine
    I am in Quetta and the quality of petrol is really low here, I've had this low mileage plus little long self problem twice. Once i serviced everything (you can find details in DIY section) and found an injector chocked (rectified it). This time i only used a cleaning agent easily available off the shelf, i was recommended to use MAG and WHIZ which i couldn't find and used ABRO (made in USA) instead.
    Both the times i revived my fuel average, quick starting and stable idle. I'm getting 15+ in local running w/o AC but i do keep my foot a little heavy on accelerator pedal
    Knocking Issue
    this is the second time i am having a vitz new shape. Knockin is inharent in this model, using 25% high octane has always been helpful. In case you don't get high octane try running on an RPM where the knocking doesn't occur.
    CAT Removal
    I don't think that CAt gets chocked so early, like under 100,000 km. In previous car i did replace it (details are available on PW, go through my profile and you'll find the thread explaining procedure). It is better to rule out other problems first, which may have caused knocking or vibrational effects. Even a visit to toyota motors will be more appropriate then fiddling with CAT on just a hunch.
    "You have not lived today until you have done something for someone who can never repay you."
    Apr 2011
    Select City
    210
    13 Post(s)
    thanks every one for reply
    but my issue is not resolve should i start praying for my better luck to make my car work smooth
    or should there be any other suggestions for me?
    murtaza_murti's Avatar
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Quote Originally Posted by bilalnoor1987 View Post
    The vibration on idle and a bad fuel average is due to a dirty MAP sensor or a clogged fuel filter. Get the MAP sensor cleaned then if that doesn't work get the fuel filter changed.
    - '06 Toyota Belta 1.0L X - '68 VW Beetle 1300 DP - '89 Nissan B12 E16
    Apr 2011
    Select City
    210
    13 Post(s)
    Quote Originally Posted by murtaza_murti View Post
    thanks murti bhaiya!
    Map sensor is located under airfilter space?????
    if so it is aslo cleaned by one of my car mechanic friend
    thye only thing that remains is to change my fuel filter
    lets see what happen ...
    Inshallah i will get the positve results after changing the fuel filter.
    i will tell the results on monday
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    ahh these JDMs r sumtimes pain in @ss.get fuel pump assy motors pressure checked it might be a culprit
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Quote Originally Posted by wasay_ahmed View Post
    It could be a dirty MAP sensor, getting that checked first would be a wise thing to do. Then if thats not the problem it could either be a clogged up fuel filter or the fuel pump fuse/relay or just a faulty fuel pump.
  12. #12
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Take pictures of the process if you can, I also need to get my Beltas fuel filter replaced as soon as I get some time on my hands.
  13. #13
    fso
    fso is offline
    fso's Avatar
    Jul 2007
    Faisalabad
    32
    1,400
    6 Post(s)
    im facing the same shity prb low fuel consumption and that knocking GOD i hate that nosie but i didnt removed the cat yet infact i had open the place below where the exaust pipe starts and there was nothing in it or may there someplace else where the cat is located if anyone knows plz do tell ....
    r3act
  14. #14
    Sep 2008
    23
    10,354
    53 Post(s)
    4 Thread(s)
    Any update?
  15. #15
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Change its plugs to Autolite Xtreme Iridiums & throtle body clean, i change plugs of many Vitz & they all running fine. cell 03214144606.
    There's no car like Mercedes-Benz.
  16. #16
    umar2606's Avatar
    Aug 2010
    106
    Most of us already know how the injectors get clogged. Its nothing but the fuel that we use, causes clogging. Every time we turn off our car's engine, last drop of petrol dries on the nozzle of the injector and leaves behind deposits. These deposits become firm with the heat of the chamber. The more we drive our car, more deposits accumulate. Gradually it starts to restrict the flow of petrol from the tiny hole on the nozzle and the injector starts to lose its efficiency. This causes the engine to lean misfire and hesitate on different rpm, power and pickup is lost, the car becomes uneconomical on petrol, unburnt fuel can be noticed in the emission and worst of all the wear of engine becomes faster. Only 8% to 10 % clogging in the nozzle can cause all this.
    Proper cleaning can restore their like-new performance. There is no need to replace fuel injectors unless they are actually gone bad. Injectors are designed in such a way that they are not very convenient to clean. They are sealed units and cannot be opened for cleaning. Ultrasonic cleaning is internationally accepted MOST effective process for cleaning fuel injectors. It is cheap and comprehensive solution for the problem.
