Results 1 to 10 of 10
Thread: Vitz 99 Brakes Issue
    nicerider's Avatar
    Apr 2011
    46
    Default Vitz 99 Brakes Issue
    Hi All,,
    I have vitz 99 and am currently facing a brakes issue. The brakes work perfectly on CNG and Petrol, but when A/C is turned on, suddenly they become hard. The situation worsens when car is in 1st gear and very low speed, the brakes almost get jammed at very low speeds, but as soon as the car gets motion again, the brakes are good to go.
    The issue is there with the brakes only when the AC is turned on. So, i think it is some power distribution issue, but am not sure.
    Also, just to add, when the car starts from halt(zero speed) with A/C turned on , the pick is almost zero and i have to turn the A/C off to get it running.
    Kindly if some experts can help me out here and perhaps refer me to some reliable person.
    kasaas's Avatar
    Apr 2006
    37
    970
    12 Post(s)
    same priblem here exactly with my vitz99. Sum 1 plz help
    BEST THINGS IN LIFE R NEVER FREE
    fas133's Avatar
    Jun 2010
    39
    177
    5 Post(s)
    Its brake booster's vacuum problem so check for any vacuum leakage when your turn on the AC. Vitz have many VSV's (vacuum switched valves) so you have to check those valves that operate at AC On specially.
    doctor's Avatar
    Jan 2005
    36
    411
    4 Post(s)
    Same problem here in Vitz 2000 model.Somebody please help....
    @fas133
    How to check VSV's?
    mrkhurshid's Avatar
    May 2008
    33
    149
    This happens with 60 - 70% of the vitz here in PK on CNG, all you need to do is to get your car tuned for a level where it is more intend towards performance than economy.
    Don't get it too much tuned for performance otherwise your economy will fall down.
    Believe me nothing wrong with your brake and all.... you can test this with A/C and Petrol.
    http://www.flickr.com/rkhurshid
    fas133's Avatar
    Jun 2010
    39
    177
    5 Post(s)
    Quote Originally Posted by doctor View Post
    @fas133
    How to check VSV's?
    You have to check these valves for any vacuum leakage.
    hdaackda's Avatar
    May 2009
    727
    2 Post(s)
    visit aa CNG mechanic... he'll adjust the settings..i found medina cng (mr kashif) on jail road to be the best
    JDM cars rock! Bus duty khatum karo pls
    shirazkhan's Avatar
    Sep 2006
    27
    1,656
    2 Post(s)
    http://www.darsequran.com/ http://www.aswatalislam.net/
    Nasirhamid's Avatar
    Apr 2010
    41
    Default break issue
    Quote Originally Posted by hdaackda View Post
    Can you please give his number
    Nasirhamid's Avatar
    Apr 2010
    41
    can you please give his number
