Results 1 to 4 of 4
Thread: Check Engine Light - Vitz 2002
    mjunaida's Avatar
    Aug 2011
    8
    Exclamation Check Engine Light - Vitz 2002
    Hi,
    I have recently installed CNG in my vitz as I was running it on petrol before. Now ever since I have started using CNG, check engine light glows after 10 5-10 minutes of driving.
    Is the issue serious and should I be concerned? Need help from Techie people.
    Thanks,
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    bro cng is not for these kinda cars!
    but if u use then these problem always rise. i.e problem with throttle body, transmission failure or heatup issues.
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    check light do the same thing in all the vitz having cng bombs!
    Junaid1981's Avatar
    Oct 2007
    34
    29
    Visit Suntech Automobiles, Mr. Awais Ur Rehman. he will solve your all engine check light problems. They have latest scanners for this purpose.
    Awais Ur Rehman 03004427008
