Results 1 to 8 of 8
Like Tree3Likes
  • 2 Post By capsat
  • 1 Post By Xulfiqar
Thread: Vitz gear box
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Default Vitz gear box
    What would be the price of a used gear box for Vitz 2004? I'm asking as the mechanic advised my friend to replace it as its jerking on gear changes, and there was water mixed with the oil on checking.
    He was quoting Rs.14,000 for used with about 2,000 to exchange the old
    Tyrone
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,586
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Thumbs up
    Flush the gear oil change the GEAR BOX oil filter and refill new gear oil, test run. it will cost you less then changing gear box on impulse because some water was mixed in gear oil.
    haroon_1's Avatar
    Dec 2010
    25
    1,589
    27 Post(s)
    ruined by using cng?
    salmanrasheedpsh's Avatar
    Jan 2011
    Peshawar
    1,708
    22 Post(s)
    in peshawar shoba u can get an auto gear box xtremely cheap ! less thn 8-10k !
    Vicky959's Avatar
    Sep 2009
    27
    323
    In earlier vitz models there is no issues with CNG.
    The question is that from where did water came into gear box. May b faulty gasket?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    water will enter the box from the oil cooler in the radiator or the breather if driven in water higher than the box.
    Just do a fluid flush with a new filter, takes about 1 hour and if still not satisfied - remove all the new fluid you pumped into the box and use it in the new transmission you get.
    Most causes are stuck modulators due to water rusting inside.
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    He panicked and replaced the gear box on the mechanic's advice as he didn't wanna take chances. Costed him 12k with exchange :-/ now its running better than before.
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    chalo ji masla apni marzi sai haal kara khush raho
