Results 1 to 6 of 6
Thread: Vitz 2001 - Sound coming from hood
    disisfifty's Avatar
    Sep 2007
    32
    234
    Default Vitz 2001 - Sound coming from hood
    Dear All, I have been facing this issue from quite some time now and i seek advice regarding the same. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:p></o:p>
    During drive, I hear a sound coming from the engine bay which is like knocking sound but quite feeble and recurring constantly. Whenever I switch AC on, the sound increases and become quite noticeable. I have changed the plugs, throttle body was cleaned to perfection but the sound is still there. Mechanic at Toyota told me that the sound is coming from the "serpentine belt" and it’s because my belt is worn out and have cracks. The said belt is of Rs. 3000 plus labor.<o:p></o:p>
    Here the question remains "weather" the diagnosis is correct or not. Should I go for the belt change or not? Advice awaited eagerly.<o:p></o:p>
    disisfifty's Avatar
    Sep 2007
    32
    234
    P.S.
    Serpentine belt is the one which goes over and around many pulleys
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    serp belt if worn would cause slip noise - high pitched squealing.
    disisfifty's Avatar
    Sep 2007
    32
    234
    nope, its not squealing sound, is more of a purrrrrrrrrrrr kind of sound. what more can be done to get rid of this noise xulfiqar sb.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    there is an adjustment on the belt tensioner, tighten it up.
    heddie19's Avatar
    May 2009
    23
    45
    Hello brother, i have seen your comment on that old forum which was
    //there is an adjustment on the belt tensioner, tighten it up.//
    I am facing the same sound when the ac is on like khurrr khurrr....engine sound is not like it used to be
    can you tell me where is the belt tensioner located so i can get it tighten up?
    reply
    thanks
Tags for this Thread
