Results 1 to 8 of 8
Thread: New tyres for Vitz 2001
    hdaackda's Avatar
    May 2009
    727
    2 Post(s)
    Default New tyres for Vitz 2001
    My vitz came with yokohama tyres, 185/65 13inch. The threads are still in good condition but recently have had 2 very bad punctures. Also, I don't know how old they are, (car second hand). Total mileage 75000km
    I was thinking of replacing them with slightly taller and less wide tyres (to improve fuel and raise height)
    Someone recommend me japanese dunlop, 175/70 13inch. For 21k for 4 tyres (he will buy my old for 1k so net cost 20k)
    What do you guys suggest? I wouldn't mind changing the rims as well, but cost is a major factor. 20k seems too high!
    JDM cars rock! Bus duty khatum karo pls
    chinyoti's Avatar
    Sep 2005
    27
    11,952
    5
    107 Post(s)
    5 Thread(s)
    ^ if u want economy, and a city driver,
    Vitz orignaly comes with 155/80r13, which are also Cultuses tires.
    If u want 14" then 185/60r14 is gud but low profile, 185/65r14 is a slightly bigger tire (3%) bigger, which would give u around 3% false meter reading
    Hope it helps.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    hdaackda's Avatar
    May 2009
    727
    2 Post(s)
    155!!
    Hmm, I might stick with 13 inches, but defenatly not 185!!
    175 or 165 is what an thinking about.
    Wouldn't 80 make it too high?
    What about costs?
    hdaackda's Avatar
    May 2009
    727
    2 Post(s)
    This is the condition of my Tyres: Will they sell? (Two tyres had bad punctures. Were repaired). The two back tyres (now in front) are good
    New tyres for Vitz 2001 - 30082010315
    New tyres for Vitz 2001 - 30082010316
    Should I buy two same tyres or get all four changed? Still confused between
    155/80r13 165/75/r13 & 175/70/r13??
    Should I change the RIM as well? (Don't want a costly option)
    hdaackda's Avatar
    May 2009
    727
    2 Post(s)
    bump
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    the car does not have the original wheel set these been exchanged locally. no japanese car is shipped with multiple BDU holes. This is done locally at machine shops. Tyre shown in the pictures seems to be in good shape if 2 are in good condition buy identical 2 and change the front ones.
    hdaackda's Avatar
    May 2009
    727
    2 Post(s)
    Quote Originally Posted by capsat View Post
    Thanks
    But to be in honest, I really am a NooB in tires. what are BDU holes? The holes where the nut goes?
    SO what you are saying is that these are good and I should just get 2 new ones?
    I don't think these tyres did a lot of mileage btw.. my car shows 75k but I bought it at 60k kms.. The import slip said it had done 56k km in japan (which I believe cause the condition was very good)
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    yes 2 are good as appearing in the picture go for new 2 same make & type.
