Results 1 to 2 of 2
Thread: needs information from vitz 2006 OWNERS
    mrh20001's Avatar
    Dec 2009
    35
    31
    Default needs information from vitz 2006 OWNERS
    dear all vitz 2006 owners.
    today i bought 2006 vitz automatic 1000 cc.
    i changed few things but my car knocks in lower gears and its pick is not good as it should be.
    kindly tell me what u guys did once u bought this model to maintain car in perfect condition.
    i changed engine oil,transmission oil,air filter etc.
    i have few questions
    now should i need to change the plugs?or only need to clean them by mechanic.
    does this 2006 model consist timing belt?
    how can i check that it can run for sometime?
    do i need to change the timing belt ?
    where from in islamabad i can find good mechaic or workshop who knows vitz best.
    kindly tell me how to increase the pick and fuel milage of this car ..
    fuzon's Avatar
    Aug 2011
    37
    180
    timing belt is changed on 100000 km so dont go for it if its not done 100000 km then dont go for it.check out the throttle body and if the accelator paddle rod and auto gear rod are attached opposite to each other then show the accelerator pedal wether to be changed or not becaz this problems occurs in auto and increase the rpm from distributor and better show it to a experienced efi engine mechanic not to every mechanic
