Results 1 to 10 of 10
Thread: Vitz Guru's help req....
    asifcae's Avatar
    Apr 2005
    33
    12,382
    59
    412 Post(s)
    67 Thread(s)
    11
    Default Vitz Guru's help req....
    sallam:
    this is myy first post here in this section:
    i have imported a vitz 2006 model and its only 27k driven......
    toyota guyz told me that i shud get my "CATALIC CONVERTER" removed from the engine as it will destroy my engine.
    plz advise me on this issue.
    shud i get it removed.....???
    if not then what precautions shud i take to save my engine and comsumption????
    thankx
    Asif Saeed
    LEGENDS OF THE NORTH
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Quote Originally Posted by asifcae View Post
    sallam:
    thankx
    Asif Saeed
    It won't destroy your engine and do not go on people advise unless you have read enough from net to support it.. look into a few threads i've made on vitz and you'll get the story .. call me if still in doubt
    "You have not lived today until you have done something for someone who can never repay you."
    ngen's Avatar
    Oct 2008
    38
    166
    it will not destroy your engine at all. if you leave it on then with time your fuel consumption will increase and the car will feel heavy to a point where it will no longer start ... once removed the car will be fine again... it's there just to convert harmful gases produced by the engine into environmentally friendly gases. the fuel in pakistan is bad so it does get choked up quickly.
    SMAFAQ's Avatar
    Jan 2012
    26
    what is catalic converter
    nnoommaann's Avatar
    Jun 2008
    Wah cantt
    31
    26
    I guess experts are here, guys i am also facing problem in my vitz 06, 1000cc auto(petrol) millage 55k. From last 2 days gear shifting is behaving abnormal. when i put D, it gives a jerk before move on, and on motorway or at 100 + engine noice (sumtimes) get change with abnormal gear behaviour. Previously this car never behave lykd this, i have drive this car arround 30,000 KMS. Oil, air filter and oil filter change in tym, and i gt it tune up from toyota dealership, 1 weak ago! Can sumone help me out? Thanks and Regards.
    HAshims's Avatar
    Aug 2004
    25
    4,886
    39 Post(s)
    3 Thread(s)
    Get your atf oil checked from toyota.
    Use only cvt oil with proper measuring.
    Honda Civic 99 EK Hatch / Honda Integra 92 DA Coupe
    RIP Adil( @AridSoul)
    faisal17pk's Avatar
    Sep 2006
    32
    180
    Default Help Required Vitz 2007
    I need help as my Vitz 2007 Model is feeling heavy on CNG and on Petrol and while its acceleration when I apply brake to slow it down a bit and then put accelerator down it does not give any response on cng and when converted to petrol it does same problem but it does give response i mean start acceleration but after a jerk.
    Visited couple of mechanics one suggested to get throttle body cleaned for 1500RS.
    Other Suggested that CAT needs to be removed and throttle cleaned for 2200RS.
    Please give suggestion as I am confused in making decision.
    Edit: Done with both and its fine now Masha Allah. Also got the culprit removed(CNG) as its of no use due to very less difference in cost per millage.
    AZEEMMAJEED's Avatar
    Jan 2009
    22
    3,313
    43 Post(s)
    3 Thread(s)
    Remove the converter thay are in favour of you
    ivtec3's Avatar
    Feb 2012
    890
    6 Post(s)
    Its for the car's own benefit.. why would you want to remove it as far as its not creating any problems?
    ivtec3's Avatar
    Feb 2012
    890
    6 Post(s)
    Quote Originally Posted by faisal17pk View Post
    The real problem there is the fusion between CNG and CVT tranny
    The jerk might be due to your car being 'tuned' on CNG hence converting to petrol is giving tht feeling in gear
