Page 6 of 6 FirstFirst ... 456
Results 101 to 102 of 102
Like Tree38Likes
Thread: Vitz 1.3 vs 1.0 fuel economy?
    blueazure's Avatar
    Jan 2012
    371
    9 Post(s)
    Default Vitz 1.3 vs 1.0 fuel economy?
    i was looking into getting a toyota vitz for personal use,, there are two models available in pak ,, the 1300cc and the more common 1000cc ,,,
    my question>
    which one has the better mileage ( ofc the 1.0 should be the better one but i heard from someone the 1300 has better EFi )
    your opinions?
  2. #101
    codenamezagr's Avatar
    Sep 2013
    30
    152
    Viytz 2006 1.3 2 bars dropped Vitz 1.3 vs 1.0 fuel economy? - 9603e03bca8418d1f72e38833e2534e8
    Sent from my LG-D851 using PW Forums mobile app
  3. #102
    umarmuslim's Avatar
    May 2008
    26
    2,776
    10
    165 Post(s)
    Quote Originally Posted by Naweed View Post
    How to tell if the engine is original or swapped? is there a possibility that fresh imported car having engine swapped while in japan or khi port, what is the check?
    auc.mycar.pk/month
    enter the cars chassis number here and itll tell u which engine it came out with from the assembly lines
    wassalaam
    Transparency & Trust @ WWW.MYCAR.PK , salaam.
