Results 1 to 7 of 7
Thread: Vitz 2006 1300cc Fresh Imports
    Mortal's Avatar
    Jan 2012
    198
    2 Post(s)
    Default Vitz 2006 1300cc Fresh Imports
    Dears,
    AOA,
    I have recently purchased Toyota Vitz 2006, 1300cc.
    Please advise me what maintenance work should be done?
    The seller has just asked me to change the air filter and engine oil.
    Any Recommendations?
    Drifter_ali's Avatar
    Mar 2009
    Neijiang
    28
    123
    WSALAM.. 1ST OF ALL Congratz 2 u .:p
    2nd is tht u should change engne iol. and air filter, it will improve performance of your cae.. okey
    z06
    z06 is offline
    z06's Avatar
    Jan 2009
    30
    2,159
    2 Post(s)
    congrats bhai..pics pics pics
    "Whoever said money can't buy happiness never bought a CORVETTE "
    ..::Z06::..
    agoodfriend's Avatar
    Nov 2011
    35
    1,551
    9
    51 Post(s)
    4 Thread(s)
    Quote Originally Posted by Mortal View Post
    Dears,
    AOA,
    call the seller and ask him what engine oil he was using in this car,,,,,,,,,,,,,,you continue using the same oil as the previous owner was using,,,,,,,,,,,,,,,,,i always carry out this practice,,,,,,,,,,,,
    fahadsoulsnatcher911's Avatar
    Jul 2009
    21
    2,876
    7 Post(s)
    whats the mileage ?
    The mileage tells the tale
    usarwar's Avatar
    Aug 2006
    30
    993
    do works according to mielage if its 50k+ then get throttle serviced, change transmission oil use a good set of plugs( i also have a 1300cc all wheel drive) i got bosch 4tip plugs, get air filter changed
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Quote Originally Posted by agoodfriend View Post
    ..........and what if the car is a fresh import from Japan?
