Dears,AOA,I have recently purchased Toyota Vitz 2006, 1300cc.(H)Please advise me what maintenance work should be done?The seller has just asked me to change the air filter and engine oil.Any Recommendations? :S
WSALAM.. 1ST OF ALL Congratz 2 u . 2nd is tht u should change engne iol. and air filter, it will improve performance of your cae.. okey
congrats bhai..pics pics pics
call the seller and ask him what engine oil he was using in this car,,,,,,,,,,,,,,you continue using the same oil as the previous owner was using,,,,,,,,,,,,,,,,,i always carry out this practice,,,,,,,,,,,,
whats the mileage ?The mileage tells the tale
do works according to mielage if its 50k+ then get throttle serviced, change transmission oil use a good set of plugs( i also have a 1300cc all wheel drive) i got bosch 4tip plugs, get air filter changed
..........and what if the car is a fresh import from Japan?
