Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By aantherax
Thread: Vitz - Amazing Impact of Changing wheels & Alloy Rims
    AbdulQayyum's Avatar
    Mar 2009
    33
    19
    Thumbs up Vitz - Amazing Impact of Changing wheels & Alloy Rims
    I have Vitz 2003 model (4 cylinder), automatic. I changed it's wheels from Dunlop (175/60/13'') to BridgeStone (185/70/13'') [model B250].I also had to use packing in it's rear suspension. It's ride has become much smooth now but I have noticed improvement in fuel consumption as well. My car model shows 8 petrol gauge lines. After wheel change I got it's petrol tank completely filled. Now before wheel change it was normally giving me 60-65 for first petrol gauge line drop (First line drop gives some extra because while filling tank completely they add some more fuel litre or so above level)i.e. average 55 km/line i.e. 55 X 8= 440 kms per tank. After wheel change it gave me 76 kms for first line. Now I am confused because following points are knocking my mind again and again.
    Has wheel change impacted this? But I don't think wheels can have this much impact.
    I also got petrol tank filled from total petrol pump. Mostly i uses PSO. Has this some impact?
    This is no other noticeable thing done with car.
    I am quite happy with my tyres and rims. I got them in 33,000 including old tyres exchange. The current bridgestone tyres have Tread Wear value of 200 i.e. 200 X 30,000 miles= 96,000 kms life. But if we consider pakistani road conditions and other factors then even if they give me 60,000 for their life then it would be really good.
    drift222's Avatar
    Oct 2011
    2,340
    211 Post(s)
    5 Thread(s)
    dear u must re-check ur calculation because the swap u mentioned has must increased your fuel consumtion more than 8% theoratically.
    to me either the mentioned tyre size is not correct or there was some problem with filling.
    Project GTxx
    ahamid's Avatar
    Jun 2011
    Rawalpindi
    125
    Worn out tyres significantly increase your fuel consumption due to more pressure loss and more rolling resistance. I bet if you replaced the same Dunlop tyres with new Dunlop tyres, you would have observed similar changes.
    drift222's Avatar
    Oct 2011
    2,340
    211 Post(s)
    5 Thread(s)
    share your experience again dear
    Project GTxx
    Porsche_Maker's Avatar
    Oct 2006
    6,388
    I think its all Total Fuel Station
    Life is a chain of moment of enjoyment and Obedience to Allah, not only about survival
    Mar 2009
    33
    19
    Default My Vitz recent average
    Currently its giving 410-420 KM's in 40 litre tank with A/C and within city. My calculations are precise as I calculate mileage with full tank . So with A/C it's giving me 10.25 km/l within city. I believe that my new tyre width would also have been consuming performance. Might be with 175/60 or 165/55 etc I will get more mileage. The above calculations given are with PSO petrol. Now these days I am checking my car's mileage with Total petrol again and let you know the results.
    I believe it's decent. The reason for this is that my car is 4 cylinder, 3 cylinder gives decent mileage as compared to 4 cylinder car. I don't want to do much experimentation with my car now for performance. Currently I am facing one problem i.e. at speed higher than 100 km/h the car stearing vibrates a bit. Can anybody help me in this regard?
    ahsanonline's Avatar
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    Wheels didn't have this profound impact. The petrol from the total pump did.
    I filled up total petrol and am able to run slightly advanced timings whereas on PSO & Shell petrol the engine would knock quite loud.
    Vibrating steering above a certain speed is because of unbalanced wheels. Get them balanced, but get them aligned first.
    Using semi synth/synthetic engine oil and with total petrol you can push up your mileage per litre up to 13/14kms (on a light, non-racy foot).
    Selling Vitz+local cars - compatible bluetooth Ecu Scantool, High-amp car chargers, Apple-certified Lightning Cables, etc. Click on my name and see my started threads for details.
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    its because of the fuel station ... i have same ride and my ride gives me 15 Km / liter and i am using 185 / 65 / 14 BridgeStone when ever i fill my car from PSO it never gives me more then 11 km / liter I get my car filled from Caltex its the best...
    ~ Be a responsible citizen and always drive safely ~
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    trust me dude i have done all my research ... Caltex is the best petrol .... gives more mileage then any other ...
    1 : Caltex
    2 : Total
    3 : Shell
    4 : PSO (the most pathetic)
    salmanghiyas's Avatar
    Jan 2009
    30
    342
    Quote Originally Posted by aantherax View Post
    True
    and always go for Caltex HOBC ...
    There are thousand solutions to a problem, Question is .... How far are you willing to go ...
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    Quote Originally Posted by salmanghiyas View Post
    True
    High Octane ?
  12. #12
    dms664's Avatar
    Dec 2007
    Select City
    33
    7,013
    90 Post(s)
    8 Thread(s)
    1 : Caltex
    2 : Total
    3 : Shell
    in Peshawar PSO is best
    Caltex walas r thieves.
    My dear ALLAH when I loose hope, help me to remember that Your love is greater than my disappointment and Your plans for my life are better than my Dreams.
  13. #13
    ghayyour1's Avatar
    Apr 2010
    Rawalpindi
    34
    215
    3 Post(s)
    1 : Caltex
    2 : Total
    3 : Shell
    my experience is opposite. I use only PSO - company operated
    1) Pso house clifton 2) pso karsaz end 3) pso at the creek avenue
    best mileage from above 3 ,
    previously used shell. Once I bought petrol for generator, shahrae faisal one, the petrol was orange (expired)
  14. #14
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    Petrol has a pinkish colour.
    I haven't tried caltex but I think caltex and total have the same source refinery. Total is good for sure. Everyone should try total petrol at least once. You'll feel quite some difference. Especially those with the newer generation cars with high compression engines such as the japanese imports and the dual vvti engines will experience noticeably better performance as well as increased fuel economy
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    why are you using such fat profile tyres on your car?? I dont know what you are calling amazing impact, I would be amazed at the bad drive I would end up with.
  16. #16
    PKTUN's Avatar
    Oct 2011
    Khuzdar
    1,067
    35 Post(s)
    3 Thread(s)
    petrol petrol hota hai neela ho peela ho petrol full hona chahyeay tankey mai
  17. #17
    tahirahmad13's Avatar
    Dec 2009
    Gujranwala
    827
    3 Post(s)
    company operated stations are face of the respective company, hence they are better!
  18. #18
    Newbie Follow
    h89alvi's Avatar
    Aug 2012
    In Lahore I use only Shell Petrol from Girja Chowk ... always works for me... but have to give Caltex a shot too...
  19. 01-09-2012, 12:51 PM
    Site Banned
Tags for this Thread
