Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By tyrone_40
  • 1 Post By salash
Thread: Toyota Vitz CVT fluid filler hole?
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Default Toyota Vitz CVT fluid filler hole?
    When servicing the throttle body and spark plugs of my Vitz 2007 I asked the guy there re: CVT drain / refill. He told me the correct fluid i.e. Toyota Genuine CVT TC. When I asked about the procedure, he said that its drained completely from below as explained in another good post here on PW, but then said that its re-filled by opening a nut bolt with "TC" written on it on the right side of the transmission. So am wondering.......???
    Will try and upload some pics later to clarify what he said
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Here are the pics:
    Toyota Vitz CVT fluid filler hole? -379231
    The pic of the nut bold with TC
    Toyota Vitz CVT fluid filler hole? -379232
    What I think is the filler hole as mentioned in the detailed PW post on CVT
    salash's Avatar
    May 2005
    Rawalpindi
    51
    300
    2 Post(s)
    The nut shown in the second pic is the correct filler point.
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Oh ok thanks
