Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 59
Like Tree13Likes
Thread: Toyota Vitz 2007 - vibration and whistling sound
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Default Toyota Vitz 2007 - vibration and whistling sound
    Hi,
    Since last two days when I start the Vitz in the mornings the car sort of vibrates/shudders for few seconds then is back to normal. This never happened before. It's like as if the engine shudders for a few secs then is back to normal. I cleaned the throttle body, spark plugs and replaced the air filter last month. What could be the problem?
    Also when I start to drive the car after its parked overnight or after work in the evenings I can hear a whistling sound which is similar to a bird chirping on the right side area. This does not happen everytime but on and off on several occasions and only for awhile but then disappears as I continue to drive the car. I can't figure out where this sound seems to come from??
    Would appreciate any suggestions help please.
    Thanks
  2. #21
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    try wd40 on centre on pully,, dont spray on belt area.
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
  3. #22
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    vibration when cold - check for HT cable for the plugs. do it yourself check with a soft gentle pull if any of the HT is lose in its socket
    whistle sound - do as LEVIN said
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  4. #23
    dms664's Avatar
    Dec 2007
    Select City
    33
    7,013
    90 Post(s)
    8 Thread(s)
    Quote Originally Posted by murtaza_murti View Post
    The 1KR-FE comes with a MAP sensor not a MAF sensor.
    thanks for the correction
    u r right its map sensor not maf .
    My dear ALLAH when I loose hope, help me to remember that Your love is greater than my disappointment and Your plans for my life are better than my Dreams.
  5. #24
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Quote Originally Posted by salash View Post
    Well in my vitz the whistling sound was coming from the rear silencer box spring bolts which had gone dry , so went to the silencer shop and got the three sling bolts oiled and the sound was absolutely gone. It is very common fault in this model , so get the bolts dipped in oil and I'm sure atleast the whistling sound issue will be solved inshallah.
    Thanks salash will try that too.
    @capsat forgive my lack of knowledge but what is the HT cable
  6. #25
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Quote Originally Posted by levin View Post
    @levin when you say centre on pulley your talking about the middle area which rotates?
  7. #26
    syed-shoaib's Avatar
    Apr 2010
    1,330
    3 Post(s)
    Quote Originally Posted by tyrone_40 View Post
    The High Tension Cables or leads which take current from coil to distributor (if available) and connects with the spark plugs. Simple speaking, I think, he is asking to check the power plug cables. He is asking to check if they are properly fixed and are not loose.
    regards,
    http://shoaibtalib.wordpress.com/
  8. #27
    Apr 2010
    1,330
    3 Post(s)
    I think he is asking about Crankcase pully or the flywheel. Most probably he is asking to lubricate flywheel with WD40.
  9. #28
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Thank you syed-shoaib. Your really a great help
  10. #29
    Apr 2010
    1,330
    3 Post(s)
    I am just hoping that I am right
    lag yeahi raha hay kah donon brothers nay yeahi kaha ho ga, as I have told. Lets hope for the best.
    Soon they will be in to verify or rectify.
    regards,
  11. #30
    AmmarShafique's Avatar
    Mar 2012
    8
    I had the same problem with my Vitz. But i had some serioes whistling noise in the first 3-4 kms. I changed my ATF and now its perfect alhamdulilah
  12. #31
    Apr 2010
    1,330
    3 Post(s)
    Quote Originally Posted by AmmarShafique View Post
    Nice to hear your problem is solved. What's you vitz model? The noise used to disappear after first 3 to 4 kilometers? Did noise use to come when you shift to "P" ? Do you have a CVT transmission or AT?
    regards,
  13. #32
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Quote Originally Posted by capsat View Post
    It's just for a few seconds after turning the ignition and stops. Its as if the car is shuddering and trying to start then its ok normal
  14. #33
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    check my signature line cut paste read and repost the details with problem again.
  15. #34
    Apr 2010
    1,330
    3 Post(s)
    Tyrone bhai problem solve hoi ap ki? Any update?
  16. #35
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    @shoaib,
    No boss. I got new spark plugs to change and see regarding the starting problem but today due to strike and busy with work since monday couldnt get a chance to change. Will update accordingly when I do.
    Thanks
  17. #36
    Apr 2010
    1,330
    3 Post(s)
    @shoaib,
    Thanks
    Ahan. Which plugs? Toyota Genuine Japan? Or some others modified ones?
    regards,
  18. #37
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Quote Originally Posted by syed-shoaib View Post
    regards,
    Toyota OEM Denso Iridium
  19. #38
    Apr 2010
    1,330
    3 Post(s)
    Excellent. Best of luck bro. Waiting for the updates.
    regards,
  20. #39
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    regards,
    Yesterday finally got a chance from my busy schedule to replace the spark plugs with Denso Iridium. Surprisingly, when I scanned and cleaned the throttle body from my mechanic last month he didnt tell me to replace the plugs as they were quite brown on the tip. Now the car is become much smoother and I can feel the difference in driving.
    However, the stuttering sounds after starting the car still remains for few seconds as I noticed this morning after the car was parked overnight. Only happens after car is parked for long durations. Next will now check the battery for any problems.
  21. #40
    Apr 2010
    1,330
    3 Post(s)
    Ahan. Nice to hear about smooth ride after getting the plugs changed.
    You are right. Battery might be becoming weak and require change.
    Best of luck bro, and keep us updated.
    regards,
