Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By Ravager
  • 1 Post By Ravager
  • 1 Post By munx12345
Thread: Vitz 2006 poor fuel consumption
    shehzad72's Avatar
    Jun 2008
    44
    75
    2 Post(s)
    Default Vitz 2006 poor fuel consumption
    My Vitz 2006 is giving me a pathatic fuel average (7-8 KMPL). I purchased it unreg few weeks back. Changed the CVT oil and got everything checked from Toyota.
    Can anyone please tell me the reason for this bad fuel consumption. I believe this model of vitz should give a better mileage.
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    my cozin is suffering from same wth similar model 1krfe is mad engine indeed.Even replaced sparkplugs checked valve clearance no idea whts the reason for this although car is running too rich.
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    be easy on the peddle. change fuel filter. use 60:40 regular and hobc mix fuel.
    cold air intake gives 2-5 mpg increase.
    get throttle body cleaned
    check tire inflation. get wheel alignment. get correct rim size for vitz.
    check you odometer. it can be miles instead of km.
    hope thatl help
    Drugs cause amnesia, and other things I can't remember
    muzi_66972's Avatar
    Apr 2012
    649
    Bro can you people give me a good suggestion as I am a lil bit confused.
    hid kits forsale in hole sale rate philips and bosch company made in germany new brand condition import to dubai bulk quantity h1. h3. h4. h11. 9005 , 9006, bulbs availble all colours bulbs avalible ( single point2 bulb and2 blaster1800 ) complet kit and ( double point2 bulb and2 blaster 1800) complet kit with checking warranty for (other cities tcs services available) for (bikes) lo voltaige1 blaster with1 bulb.
    M getting these from a place in 1800 Rs for my car, is this price is okay or not? Please help.
    Regards: Muz 66972
    Nostalgia :-P
    farhan1196's Avatar
    Oct 2009
    33
    21
    Aoa meri belta ke sath yahi problem thi 1300cc milag local 10 se 11
    long 12 se 13 k/l
    main ne fuel filter aur fuel jali chnage ki use ke bad
    local 13 se 14 k/l aur long 16 se 17 k/l
    at speed 130 se 140
    now i really enjoy my belta
    plz change fuel filter and fuel jali
    :d
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    did you tried throttle body servicing? also check for ignition cables.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Nov 2006
    29
    4,959
    12 Post(s)
    SO far the Jobs we have gone through
    Intake manifold service.
    Brandnew sk20hr11
    Valve Clearance checking ahh the stupid mechanic didnt told the reading to my driver
    Toyota CVT FC gearoil with Pan cleaning
    Brandnew tyres wheel balancing and alignment on stock 14s the tyres are not much oversized indeed.
    IT test.Again didnt told the AFRs etc
    @aftermkt intake
    It disturbs the idling
    Yet iv maintained my vitz 04 myslef alljobs DIY and it gives alhumdulilah 11 12km although its not in as good shape as this 07 is. https://www.pakwheels.com/forums/d-i...71700-wrd-vitz
    Ravager's Avatar
    Oct 2007
    28
    2,025
    46 Post(s)
    4 Thread(s)
    @ wasay bro not to be rude. but with "did" always use the first form of verb.
    like i did go to the party. instead of i did went to the party.
    reading you use the second and third form every time. really annoyed the crap out of me
    shehzad72's Avatar
    Jun 2008
    44
    75
    2 Post(s)
    Quote Originally Posted by farhan1196 View Post
    long 12 se 13 k/l
    at speed 130 se 140
    :d
    Thanks I'll change the fuel filter and jali. Whats the price of fuel filter?
    mardanian2010's Avatar
    May 2012
    Mardan
    my vitz'07 is giving me 15kmpl wid ac in local.
    and above 20kmpl wid ac on highways.
    driving smooth with constant acceleration.....will help alot.
    ImPeCcAbLE's Avatar
    May 2006
    28
    107
    Quote Originally Posted by Ravager View Post
    Agreed 100% as I have tried and been using these measures .. also would recommend to remove the catalytic converter, my car is now giving me abt 14-16km/l
  12. #12
    ghezwan's Avatar
    Nov 2008
    42
    16
    Bought a Vitz after selling my second car reborn 07 and alas my biggest mistake, reborn was much cheaper on petrol than this vitz.....of course change of plugs, removing catalytic are some 50-50% chance game but not a surety its just a matter that u buy a better vitz or get something back......so what i did was sold my vitz and bought a honda again atleast if my car drinks petrol let it b a car as good as honda
  13. #13
    tyrone_40's Avatar
    Jan 2005
    Other
    1,600
    13 Post(s)
    Quote Originally Posted by capsat View Post
    Could u pls explain by what you mean to check for ignition cables?
    Also what is valve clearance and how is it done?
    Thanks
  14. #14
    Newbie Follow
    munx12345's Avatar
    Nov 2008
    30
    change your air filter ppl toyota dealerships pe or baher se jo air filter 400 500 ka milta jaise gard ka or lippon ka ohh matt use karen usse avarage nai ati use its original filter jo denso ka hai costs 1500 to 1600 usse avaerge ati hai because uska material dusra hai i have been useing vitz from last 2 years usse phele passo city mein with a/c 10 dehgi in normal traffic signal stops wagera keh hisaab se and buy a nasa carborator cleaner spray har 1000 km pe filter ko hawa lagwo or spray karwalo trottle pe machinic se avarage sahi dehgi or viberation jo 1000cc engine mein ati hai ohh bhi nai ayegi and pick bhi perfect rahe ga plus check yout CAT (cathalatic converter) ohh chock hota hai to bhi avaerage nai dehti or pick beth jata hai if u need any more info about your vitz passo or belta engines feel free to contact me 03332898462
  15. #15
    epigenius's Avatar
    Apr 2012
    1,085
    33 Post(s)
    Quote Originally Posted by wasay_ahmed View Post
    Brandnew sk20hr11
    @aftermkt intake
    Quote Originally Posted by shehzad72 View Post
    have you guys checked your car for clogged catalytic converter it is usually the culprit
