Results 1 to 6 of 6
Thread: vitz 2000 model creating pressure in pipe leadining from radiator to engine...neee
    usmanyo2k's Avatar
    Aug 2011
    Default vitz 2000 model creating pressure in pipe leadining from radiator to engine...neee
    hey guys
    recentlytly purchased a 2000 vitz.....after a few days drive when i opened the hood and checked the coolent pipe leading from radiator to engine , found it really tite...rather extremly stiff like it will be bursting in a while...i imediately went to my mechanic and told him about the problem ...he told me that he will get it check in detail after opening it as it may be the problem of gaskit or may be another....in short i got the head of my car opened and found the head to be ok...block to be ok.IN SHORT NO SIGN THAT CAR WAS heated befor..piston and syclinders were also fine...even then on saying of mechanic i got my gaskit changed...got the head phased and got the valve changed.....for few days the pipe behaved normally but after that the pipe started getting stiff again...i got it checked from another mechanic who told that JAPANESE CARS ALWAYS PRODUCES PRESSURE..engine is in waterdropping condition on the whole but ....in short the problem is still there and am really worried as i feeeel that the pipe might burst on long drive with the constant pressure in water pipe resulting in engine getting seize amd trouble.........
    guys am reallly worried .....so kindly help me out with your suggestions and possible solution
    thankyou
    waiting for your replies
    hash4u's Avatar
    May 2005
    38
    24,379
    18
    406 Post(s)
    13 Thread(s)
    13
    Whr thr any other symptoms which lead u for such major work
    Does this car have a temp gauge or jst indication lit
    usmanyo2k's Avatar
    Aug 2011
    no guage due to degital meter..which is greeen indication lit in lmorning( as engine cold) and uptill now the red indicatioon lit hasnt apeared but i am doubtful that it may appear ............no other indication was there before such work...jut tht water pipe pressure made me go for tht work and the problem still not solved
    usmanyo2k's Avatar
    Aug 2011
    can anyone confirm me first that is this true that ALL JAPANESE CARS MAKE PRESSURE(more or less) IN THE PIPE LEADING FROM RADIATOR TO ENGINE????
    tayyabbaig's Avatar
    Nov 2008
    Oslo
    34
    2,706
    3 Post(s)
    Check the thermostat valve, it could be stuck closed. Though its a common thing but could have been skipped from the mind of ur mechanic mind.
    usmanyo2k's Avatar
    Aug 2011
    thermostate valve was checked again and again and was replaced but problem stays still
