Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By Xulfiqar
  • 1 Post By shqasmi
Thread: Vitz 1st gen gear weakened
    Erawen's Avatar
    Apr 2011
    99
    Default Vitz 1st gen gear weakened
    Dear friends,
    Yesterday evening when I started my car after
    A three four hour break , a strange sound like a broken bearing
    Or something started comiNg from the gear.
    On taking her for a checkup at mechanics, he diagnosed her with a weak gear.
    The car was also giving big jerks when the gear changed. After that he said he has done bit of settings , but it won't last long and the problem won't go away unless the gear is changed.
    But he advised me not to change the gear instead sell the car.
    Now my question from you experts is that what is better , changing the gear or the car? If I change the gear , will the car be back to perfect ?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    if its a broken bearing sound then its most probably your torque converter is done, driving more like this will end up in a completely dead transmission as fine metal particles of the torque convertor will slosh throughout the transmission.
    shqasmi's Avatar
    Oct 2005
    32
    1,355
    selling the car is not a good solution, also you will not get your desired amount in that condition. vitz AT is cheap here in KHI you will get a good kabli one in 6k from sher shah.
    HONDA the power of TOYOTA's dreams...
    Erawen's Avatar
    Apr 2011
    99
    6k sounds cheap i doubt though, i went through and found alot between 10-15k in shershah. depending on the warranty !
    i dont know much about the condition of those gears, but i do trust the mechanic i went with.
    Erawen's Avatar
    Apr 2011
    99
    and will changing the transmission get the car back to its original condition ?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,587
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    buy transmission complete with Torque converter sometimes mechanics & yard guys CHEAT around to make extra cash. ensure that you change transmission filter & transmission oil when doing swap with damaged unit. car will run fine
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
