Results 1 to 19 of 19
Like Tree1Likes
  • 2 Post By hassan4772
Thread: Vitz Vibration
    nasty_faizan's Avatar
    Mar 2008
    26
    190
    Default Vitz Vibration
    I own a 2007 vitz. Today, I got it's battery changed since the old one died. The new battery is AGS 60 CNG(my car is on patrol). After the battery change, the car has started to vibrate violently in idle. In neutral, park or in drive without pressing the accelerator. As soon as I press the accelerator, the vibrations stop and starts behaving normally. The car was fine this morning, the problem started after I got the battery changed.
    Also, I cleaned the air filter while I was at the shop. I have checked if I hadnt replaced the filter correctly but it seems fine.
    Experts please tell me what to do now.
    "Mian, mainey to tumharay abba ko bhi theek kia hai...."- Baba Hassan.
    salash's Avatar
    May 2005
    Rawalpindi
    51
    300
    2 Post(s)
    Same thing happened to my car after battery change , well I disengaged the battery terminal for few minutes to reset the ecu and also got the throttle body serviced at the same time and the car was back to normal. It worked for me u can give it a try.
    Mar 2008
    26
    190
    OK i will try disengaging the battery right now and see what happens. Where did u get the throttle body serviced from? Some toyota 3s or another mechanic? I still am unable to find a good mechanic for my vitz
    Mar 2008
    26
    190
    45 views and only 1 reply. Looks like this issue isnt very common.
    hassan4772's Avatar
    Nov 2009
    618
    have you confirmed that the 60 amperes battery is compatible with your car's generator? The vibration might be due to the drop in the engine rpms because of the generator working under stress to charge the 60 Amp battery.
    What we do in life, echoes in eternity!
    hassan4772's Avatar
    Nov 2009
    618
    i guess it doesnt has anything to do with the ecu reset.
    hassan4772's Avatar
    Nov 2009
    618
    check the amps of the stock battery, if they are less then 60, then IMO the reason for vibration is what i have mentioned.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Vitz comes with a 45 AH battery. Check for (-) black wire negative connected properly to the ground. Test with a wire loop connect to battery NEGATIVE connect to engine head or block directly start the car and let it idle see if there is a change most likely it is grounding problem nothing doing with TB
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    ahsanonline's Avatar
    Jan 2007
    Rawalpindi
    86
    2,295
    19 Post(s)
    3 Thread(s)
    Just drive your vehicle around a few days, it'll be fine.
    Selling Vitz+local cars - compatible bluetooth Ecu Scantool, High-amp car chargers, Apple-certified Lightning Cables, etc. Click on my name and see my started threads for details.
    Mar 2008
    26
    190
    Thanks for your suggestions. This morning I disconnected the battery and after a few minutes reconnected it again. Works fine now. I guess it was something related to the ECU after all.
    dms664's Avatar
    Dec 2007
    Select City
    33
    7,013
    90 Post(s)
    8 Thread(s)
    Quote Originally Posted by nasty_faizan View Post
    yup and it was not becoz of battery but becoz of the reason that u cleaned ur airfilter.
    Good to know its working fine now
    My dear ALLAH when I loose hope, help me to remember that Your love is greater than my disappointment and Your plans for my life are better than my Dreams.
  12. #12
    6Forward's Avatar
    Feb 2012
    203
    1. Clean the throttle body
  13. #13
    Romiii's Avatar
    Jun 2012
    9
    Faizan, wats the mileage of ur vitz???
  14. #14
    RUSTY's Avatar
    Feb 2010
    28
    110
    bro i own a 2008 nov model vitz i went to toyota motors their senior mechanic told me if your car vibrates then dun worry or take tension because this is normal with vitz just clean your throttle body clean your air filter thats it and just open the air filter box and clean the throttle body with throttle body cleaner
  15. #15
    Toyotalover86's Avatar
    Jun 2012
    Post Vitz Vibration 2
    I faced the same problem with my vitz 07 1000 cc. i changed the battery... installed AGS 48.. The car started to shiver vigorously in idle start mode. but a couple of hours later when i went out on the car it felt better, the vibration automatically reduced to a great extent, does that mean that its ECU adjusts itself with the passage of time??? i am afraid that i might not face the same problem again.. i need your expert opinion on this one guyz!!!
  16. #16
    Jun 2012
    Guyz please also suggest some good mechanic for my vitz 07 in Islamabad.
    Thanks in Advance
    Cheers!!
  17. 16-08-2012, 11:06 AM
    Site Banned
    Reason
    local spammer
  18. #17
    shoaib.nabeel's Avatar
    Feb 2013
    34
    29
  19. #18
    Newbie Follow
    taymoor1's Avatar
    Jul 2013
    hi today i got the same problem i changed the battery and when i started car vibrates. what to do??
  20. #19
    hraza's Avatar
    Jun 2007
    50
    6
    Default vitz idle rpm after battery replacement.
    I want to share here my experience of low idle rpm after battery replacement in vitz 07. This thread helped me a lot. I tried many suggestion of this thread i.e disconnect the terminals and connect and others but no trick worked. At last I leave it. After some days it has fixed . nothing is done. Now its OK. Thanks all, thanks Pakwheels.
