Results 1 to 13 of 13
Thread: Engine Light :( Vitz 2000 Auto No CNG
    somisomi's Avatar
    Jul 2009
    Rawalpindi
    30
    13
    Exclamation Engine Light :( Vitz 2000 Auto No CNG
    Hi Guys,
    I'm getting the engine light for last two months, it comes up after driving for sometime. I've put in new engine oil, changed air and oil filters, had service but the light just wont go.
    I've not installed CNG, model is Vitz 2000' auto, car on petrol, Driven 104,000.
    Also, any good ISL/RWP mechanic with reasonable prices? The one I goto couldnt figure out what's the problem and I've asked around and no one can pin point it so I'm here for your expert opinions
    Thank you,
    Best Regards.
    AZEEMMAJEED's Avatar
    Jan 2009
    22
    3,313
    43 Post(s)
    3 Thread(s)
    Get it checked by arshad electriciAn at chah sultan rawalpindi
    mikmech's Avatar
    Jun 2012
    Edinburgh
    117
    you need to go to a workshop which has a automotive scanner cause i think some has messed with your throttle body...then you need deceleration caliberation which can only be done by a scanner.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    you may need to change the timing belt if the ODO meter is not tampered and reading is correct as you mentioned. However you need to visit some shop with scanner and extract the codes. DO NOT - repeat DO NOT ask the shop to reset the code if it is for timing belt change the belt before doing a reset.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Site Banned Follow
    engineermali's Avatar
    Jul 2009
    Quetta
    35
    7,883
    113 Post(s)
    25 Thread(s)
    computer checkup karwawo
    Site Banned Follow
    Jul 2009
    Quetta
    35
    7,883
    113 Post(s)
    25 Thread(s)
    Quote Originally Posted by capsat View Post
    Vitz mein timing belt nahi hota
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by engineermali View Post
    which engine type it is ?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Timing Chain
    somisomi's Avatar
    Jul 2009
    Rawalpindi
    30
    13
    Yea there's no timing belt, rather a chain so it doesnt need replacement after 100k, that's what my mechanic told me.
    Anyway, thanks for your feedback guys, do you know of any shops with scanner preferably in RWP else Islamabad? I know of Auto 2000 in Scheme III ext, but the guy charges alot, that's fine and all if you're taking a merc or something, but its a Vitz ;p sooo
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    go to Hyundai Sowan Motors (Rawalpindi) or Pak Suzuki workshop (Rawalpindi) both are on G.T road /Jehlum Road near Sowan Adda..
    they got OBD scanners...they will charge no more than Rs.500/- for scanner ....get the codes read and then you would know whats causing the check engine light....
    somisomi's Avatar
    Jul 2009
    Rawalpindi
    30
    13
    Thanks Bro
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    hmm 500.. I used to charge Rs 1000/- but also offered a cold/hot drink of choice and a complete printout of the fault.
  13. #13
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    why are u equating urself with them.... there r many things in the world tht arent quantifiable
