Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Xulfiqar
Thread: Toyota Vitz 06, slow gear shift response
    aliayub's Avatar
    Jun 2011
    Default Toyota Vitz 06, slow gear shift response
    Hi,
    can anybody please guide me on the issue that i have 2006 Vitz automatic... when the engine is cold, the gear shift response is excellent & quick but after few minutes when it's cold symbol goes off then gear shifting becomes very slow... like if im going on high gear and suddenly if i need pick and i press on the paddle it goes to the lower gear very slowly resulting in slow pick... it feels like something stops it from lowering the gear quickly and efficiently... i was thinking does it hav to somthing with gear oil?...
    Thanks
    ayubian2's Avatar
    Jul 2011
    Peshawar
    53
    janab when u suddenly press the padle, the vitz goes into lower gear for good pick. its a company added feature, its not a fault. ok
    haroon131's Avatar
    Aug 2005
    31
    299
    change transmission oil if u are facing shifting problem.
    doubletrouble's Avatar
    Mar 2005
    27
    1,574
    get the gear oil checked ..
    by the are you running on gas? .... CNG has tendency for sluggish shifts
    drug-s3x-money .....be careful: this is the kind of obsession that can render you utterly useless
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    when the system is cool the torque convertor will not lock and the transmission will delay all gearshifts - to get the engine to warm up quickly. Once warm it shifts normally - which you are considering as something is wrong.
    Delayed downshift?? can you explain that more precisely.. The autobox will downshift and it will take time to downshift - do not expect it to shift like a BMW M or mercedes AMG
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    @xulfiqar bhai...kindly clear your inbox or advise here:
    https://www.pakwheels.com/forums/oil...apacity-sludge
    thnx
