Results 1 to 7 of 7
Thread: Toyota Vitz Petrol Problem for few minutes after starting
    awais-idrees's Avatar
    Feb 2010
    108
    Default Toyota Vitz Petrol Problem for few minutes after starting
    Hey guys, I have toyota vitz model 1999 1000cc.
    It on CNG and i do drive on petrol sometimes and you must know that these cars always starts on petrol and than convert to CNG automatically after sometime, so it was going ok since last 2 months, in last 2 months I've experienced strange problem i.e. whenever i start my car it gives strange sound like it was going to off automatically and when i try to give manual race it doesn't pick it and vibrates and gives a sound like it was going to shutt down and sometimes it does shutt down when i try to give race to give the engine the power to get smooth. It only happens a few minutes and afterwords it runs smoothly.
    I've get it checked by mechanic and he said its fuel filter needs to be replaced and i got it replaced but still the problem was there, than again i get to the mechanic and he said i need to change the fuel motor as it gets weak and than i replaced the fuel motor but still the problem is there.
    Can anyone please help me out???
    This only happens on petrol and for very few minutes after i start the car and very rarely happens while driving.
    It nevers happens on CNG.
    Please guys help me out or tell me about a mechanic who can fix it well.
    You can also contact me on my number 0321-4055485
    please i need sincere advice
    Thanks in advance
    Feb 2010
    108
    Quote Originally Posted by awais-idrees View Post
    Thanks in advance
    Help me with this guys please...
    Feb 2010
    108
    Thanks in advance
    Can't anyone reply to this thread???
    noormuhammad001's Avatar
    Dec 2011
    Facing exactly same problem!!! Doesn't any one have a solution for this?
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Get the fuel rail & injector cleaned.
    Never loose hope in life,every step gives u something.
    ngen's Avatar
    Oct 2008
    38
    166
    Get your CNG advancer / Emulator checked ... if you have changed both the fuel filter and the pump then it must be the CNG system which is creating the fault.
    5555's Avatar
    May 2009
    25
    688
    3 Post(s)
    first of all unplug your battery for about 5 min then replug the battery terminal then check if car is ok
Tags for this Thread
