Results 1 to 10 of 10
Thread: Urgently Need HELP Toyota Vitz Petrol Problem for few minutes after starting
    awais-idrees's Avatar
    Feb 2010
    108
    Default Urgently Need HELP Toyota Vitz Petrol Problem for few minutes after starting
    Hey guys, I have toyota vitz model 1999 1000cc.
    It on CNG and i do drive on petrol sometimes and you must know that these cars always starts on petrol and than convert to CNG automatically after sometime, so it was going ok since last 2 months, in last 2 months I've experienced strange problem i.e. whenever i start my car it gives strange sound like it was going to off automatically and when i try to give manual race it doesn't pick it and vibrates and gives a sound like it was going to shutt down and sometimes it does shutt down when i try to give race to give the engine the power to get smooth. It only happens a few minutes and afterwords it runs smoothly.
    I've get it checked by mechanic and he said its fuel filter needs to be replaced and i got it replaced but still the problem was there, than again i get to the mechanic and he said i need to change the fuel motor as it gets weak and than i replaced the fuel motor but still the problem is there.
    Can anyone please help me out???
    This only happens on petrol and for very few minutes after i start the car and very rarely happens while driving.
    It nevers happens on CNG.
    Please guys help me out or tell me about a mechanic who can fix it well.
    You can also contact me on my number 0321-4055485
    please i need sincere advice
    Thanks in advance
    mikmech's Avatar
    Jun 2012
    Edinburgh
    117
    @Awais-idrees does your mechanic have a car DTC scanner????
    mikmech's Avatar
    Jun 2012
    Edinburgh
    117
    Quote Originally Posted by awais-idrees View Post
    Thanks in advance
    is it a 5 wire etcs throttle and cable driven throttle???
    Feb 2010
    108
    Quote Originally Posted by mikmech View Post
    No mikmech he didn't had one
    Feb 2010
    108
    its a cable driven if i m not wrong
    mikmech's Avatar
    Jun 2012
    Edinburgh
    117
    in let air actuator (iacv on the thottle body)and sensors need to be checked, good scanner will do the trick, by the way is the engine check on??
    Feb 2010
    108
    @ mikmech: no, engine check is not on. can u pls suggest a mechanic in lahore who can find out the actual problem???
    mikmech's Avatar
    Jun 2012
    Edinburgh
    117
    @awais idrees try magic motors in model town
    https://maps.google.com/maps?hl=en&q...ahore&ie=UTF-8
    Feb 2010
    108
    where is it exactly in model town???
    any contact details???
    Feb 2010
    108
    anyone else?
    anyone having any better suggestion????
Tags for this Thread
