Results 1 to 16 of 16
Thread: Vitz 1sz/2SZ [What is this thing]
    leolove110's Avatar
    Jan 2012
    28
    Default Vitz 1sz/2SZ [What is this thing]
    Vitz 1sz2SZ What is this thing -456260
    Can someone tell me what is the thing highlighted in the picture? What is its function and how to and where to connect it?
    It has electric connection and 2 pipes left and right. Vitz or Belta owner can find it under their hood.
    Please help me its urgent!
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    As Per I Know....Looks Like Charcol Canister Vacuum Switching Valve(VSV)
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Its Connected To EVAP Bottle One Pipe And Other To Somewhere On TB....!!
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Quote Originally Posted by SER_GTR View Post
    canister purge valve right - but does it come in all Vitz cars or only cars from UK have that unit?
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    leolove110's Avatar
    Jan 2012
    28
    I have this with my filter box but where is bottle? Do I need to buy it?
    what is the function of this?
    What side effects not to use it?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    trace the pipes one must be connected to carb & other to the canister if it is not removed by USTAAD the basic function is emission control
    leolove110's Avatar
    Jan 2012
    28
    Quote Originally Posted by capsat View Post
    Its an EFI engine. what do you mean by carb?
    its actually an alteration in Charade.
    Car is hesitating to revive and idle problem on cold start and low rpm on normal.
    I am checking one by one everything as mechanic in lahore are full paindu :p someone tried to put a card board on the intake throttle to resolve missing problem :p
    That is why only way is to get everything myself checked.
    is it compulsary component or any enhancement?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    by carb i meant fuel feed be it injector feed or injector rail or a carb
    if you can remove and snap a close-up picture then it will be more clear. Because the problem you are stating is related to MAP/ MAF sensors and this emission control valve have very less effect on cold start / idle speed.
    leolove110's Avatar
    Jan 2012
    28
    Hi.
    Thanks and sure. I willl get the close snap on Monday.
    Another question is:
    I tried to push throttle all of sudden at idle. It seems it was hesitant initially but suddenly took boost after 3500 RPM. I believe that is vvti?
    I used taiwan fuel pump with existing lines of charade and there is no return line.
    Can you tell me:
    1. Standard fuel pressure for 1300cc car
    2. Fuel piping size, like what should be the diameter of main line and return pipe?
    3. Fuel pump regulator should be installed in hood or in fuel tank? I see one which can be install with fuel pump in tank.
    I believe I am laking fuel pressure due to which the car is hesitant and does not giving me a boost. Although I have tested the car with 100KM/hr speed. still feel the engine can serve more.
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    Since Its For Emission Control...There's No Need To Hunt for it Too Much.....!!
    Its Connected All The Way....
    You Should Have Around Maintained 35-38Psi In Order To Run your Car Smoothly....!!
    adjustable Fuel pressure Regulator are for cars with return line....in your case....there's none...!
    also check for any vacuum leaks and do check your Fuel pressure
    leolove110's Avatar
    Jan 2012
    28
    Thanks.
    My car does not require return line????? Where will the excess fuel go? :p
    I will check fuel pressure and vaccum leaks on Monday for sure.
    Are you sure there will be no return line? Pump does not starts when we switch on the engine but rather when the self starts and it is connected to ECU not to ignition.
  12. #12
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,960
    12 Post(s)
    hmm so u swaped in 2szfe in Charade. Nice!
    Baki check fuel filter and fuel pump.If uv gone for used fuel filter n fuel pump then better go for fuel pump any fuel pump of bosch denso etc applicabe for toyota xli etc is good enough.Im using chinese Osaka Gold fuel pump in my 1000cc and response is great
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
  13. #13
    leolove110's Avatar
    Jan 2012
    28
    Quote Originally Posted by wasay_ahmed View Post
    Hi,
    Thanks to SER_GTR for his guidance. swap is under his virtual supervision
    The swap was neat. I dont like the way mechanic made the bracket for mount but in the end, I was the one with 103KG who was standing and jumping on the engine and I didnt hear any cracking noise.
    I am having a problem. The problem is, I am using an in tank fuel pump bought new from shop. The fuel line I am using is existing old charade line which is I believe is narrow.
    The car is missing on idle and when after sometime, it gets a bit steady but as soon as i push the throttle all the way, it starts woobling as there is no fuel to feed.
    KEEP IN MIND THIS IS A RETURNLESS FUEL SYSTEM and my system is purely returnless I mean I even dont have regulator in tank lol, pump directly feeding injector rails.
    I tried to WOT and when the engine starts woobling I put a spray of petrol and it goes like normal. Everytime I did this, seems problem resolve.
    So I conclude with my limited knowledge that either it is a low or high pressure problem.
    what should I change? fuel line, pump, or what? I see there is a regulator on injector rail as well. should I play with it?
  14. #14
    leolove110's Avatar
    Jan 2012
    28
    Still waiting for help guys
    1. I have no FPR neither in tank nor outside. I am unable to find aftermarket FPR in lahore please help what to do?
    2. IDLE has missing!!! I believe that is due to bad fuel system? (working fine on cng)
    3. bad fuel average.
    4. Radiator!!!! Do I need bigger radiator as car is heating at optimum temperature and fan is automatic. when driving more than 100 KM, fan starts continously and after 4-5 KM, I can see the needle starts moving up. I have Charade 84 double naali silver radiator but dont know its condition. Should I change? Which for I should go? I dont mind if I have to go with new.
    5. None of the mechanic I have met has pressure tester where to buy it so that bloody I can check myself?
    6. Bad EFI wiring? I asked CNG mechanic to install lendi renzo kit but he put tomasetto advancer and emulator saying that your MAP sensor white wire does not have any pulses get it check first. I double he is liar. Any help?
    SER_GTR bro I am planning to get radiator, wiring and AC done and wants to get a thorough scan from your mechanic in karachi. Will that be okay?
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    the original fuel pump jug of vitz and corolla or any car with returnless fuel line actually has an FPR - its housed inside the pump jug, If you open up the jug and inspect there is a FPR looking device in it which just dribbles excess fuel.
  16. #16
    leolove110's Avatar
    Jan 2012
    28
    Thankz Zulfiqar,
    But the inline FPR you are talking about cannot be adjusted
    For example, if I get vitz one it might be the one comes in 1000cc hence low pressure and I will stuck again.
    Also, the jug is very big for Charade tank alternation I believe? Correct me if I can put the jug inside itself or just get FPR from the jug and install it with welds and alteration along with fuel pump?
    Currently, the fuel pump is attached with a proper "fuel pump only" assembly and it is just few mm above the base of the tank. I was not able to find any jug which can be fit in charade tank. The depth of the tank is 7Inch and the minimum jug I saw is about 9-11 inch.
  17. 28-08-2012, 12:42 PM
    Site Banned
  18. 28-08-2012, 12:47 PM
    Site Banned
    Reason
    local spammer
  19. 28-08-2012, 12:49 PM
    Site Banned
    Reason
    local spammer
  20. 28-08-2012, 12:50 PM
    Site Banned
    Reason
    local spammer
