Results 1 to 17 of 17
Like Tree5Likes
  • 3 Post By capsat
  • 1 Post By argtr65
  • 1 Post By chinyoti
Thread: In Big Trouble with VITZ 2005
    asimkh1's Avatar
    May 2010
    33
    199
    Default In Big Trouble with VITZ 2005
    Dear Experts plz plz plz help me.
    I have overhauled my vitz 2005, 1000cc.
    Now when i started the car first time it was ok.
    The problem is when i start driving the car the RPM goes high even if i don't touch the acceleration pedal the cars goes to 60 km/h & If I put the car on Parking or Neutral the RPM get normal.
    Issue:: RPM goes high when only car is in drive & reverse mode.
    Furthermore the engine light is also came up.
    My mechanic is saying we will reset the ECU with the scanner computer & your problem will be resolved. But i know my mechanic he is just doing hit and try methods. Because he first said that adjustment screw of throttle is not in proper position but no change after adjusting it.
    Experts kindly help me in this matter, also advise a good mechanic who can solve my problem
    mikmech's Avatar
    Jun 2012
    Edinburgh
    117
    does your vitz have electronic acceleration pedal
  3. 01-09-2012, 11:34 AM
    Site Banned
  4. #3
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,592
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    you can reset the ECU to defaults - turn key to ACC only, remove the positive terminal of the battery for 3 minutes. re-connect the positive terminal back to battery. turn key to OFF, pull it out, re-insert and start the car, come back to forum with findings.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  5. #4
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Make sure,kick down cable is properly adjusted.
    Never loose hope in life,every step gives u something.
  6. #5
    asimkh1's Avatar
    May 2010
    33
    199
    I have check the error code and it was p0011, which is for vvt sensor. i just removed it out and clean it with petrol and it was good to go. hence my big problem is solved now.
    But guys i have one more problem, when i start my car after 4-5 hours mean cold start.... the car sounds like tak tak tak but this sound go off after 10 - 15 mins or its too low that i cant hear.
    kindly suggest me what is the possible problem
  7. #6
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    It could be because of low oil pressure or using of wrong grade oil.
  8. #7
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    clacky startup is caused by a worn out VVT system, just cleaning does not work, you need to replace it with a new part. btw - when you overhauled the engine did you replace all the timing chain guide rails?
  9. #8
    chinyoti's Avatar
    Sep 2005
    27
    11,954
    5
    107 Post(s)
    5 Thread(s)
    Unhappy
    Overhauled a 2005 Vitz , Whats its mileage?
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
  10. #9
    drift222's Avatar
    Oct 2011
    2,340
    211 Post(s)
    5 Thread(s)
    Quote Originally Posted by capsat View Post
    Really glad to know that there are people with knowledge to help
    Project GTxx
  11. #10
    asimkh1's Avatar
    May 2010
    33
    199
    actually bhai my mechanic have same engine in his workshop he just took out the vvt sensor from there and put in my car, after which my problem was solved.
    but for the sound problem (tuk tuk tuk when engine is cold) he is saying to reopen the engine and to check it with kharad for the sizes of every part
    timing chain guide rails were not replaced, plz let me know do i have to change them too
    my car millage is 110000 and it was giving smoke at high rpm.
  12. #11
    chinyoti's Avatar
    Sep 2005
    27
    11,954
    5
    107 Post(s)
    5 Thread(s)
    Are you sure it was the engine that needed overhauling? Or could be repaired by changing some seals, I doubt a properly maintained Mehrans engine doesnt dies at 110k kms
  13. 05-09-2012, 01:29 PM
    Site Banned
  14. #12
    asimkh1's Avatar
    May 2010
    33
    199
    Quote Originally Posted by chinyoti View Post
    actually my cars rings & valve seal were worn out, and i have personally check the cylinder and piston they are good for more 20 - 30 thousand kilometer .... but i also changed them.... one more thing my meter is showing 110000 but i dont know the actual millage.
    the things changed are:
    3 Pistons (Standard size)
    Piston rings (Standard size)
    valve seals (Standard size)
    the thing which were prepared by kharad
    cylinder sleeves (to get piston of standard size)
    valve grinding for perfect comparison
  15. #13
    asimkh1's Avatar
    May 2010
    33
    199
    Quote Originally Posted by Jibran.kamal View Post
    I was also in problem with this problem.. but i solved this problem by reading this article.. click on below link & u will get the article..
    Metro MR-70 For sale in Lahore - Free Classifieds in Pakistan 3 Sep 15:26
    Remember me in ur prayers
    Y u people are misleading & posting irrelevant links ..... try to practice good SEO techniques.
  16. #14
    raza1's Avatar
    Nov 2006
    3,206
    2 Thread(s)
    ^^ he is a spammer, remove his post quote from ur post, he will be history soon.
    All are invited in Party tonight at my Signature space.
  17. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by asimkh1 View Post
    The piston/bore clearance is a little large on these later toyota engines, (you put in new sleeves - real sad), the engine block has siamesed sleeves which are put in as one part then the block is cast around it, If it wears out for any reason oversize pistons are required, once the block goes to its max oversize the block is scrapped.
    The timing chain is measured for wear by measuring how many degrees the cam is off compared to the crank, When that chain is replaced, the guides are also done for their life and replaced along with the tensioner, the cogs are also checked and replaced if they are hook shaped.
    Still 100,000 kms is nothing for a modern day engine, if it was smoking at high revs, you should have done proper diagnosis first, 90% of cases are bad valves/guides/seals. The block is very long lasting if proper oil changes and temperature were maintained.
  18. #16
    fminhas's Avatar
    Mar 2006
    39
    172
    hello are you there man
  19. #17
    fminhas's Avatar
    Mar 2006
    39
    172
    Vitz is a nice car. I like it
