Closed Thread
Results 1 to 8 of 8
Thread: Rim Size for Vitz
    mnaeem's Avatar
    Nov 2005
    43
    39
    Default Rim Size for Vitz
    What should be the best rim size for Vitz for driving on Roads of Karachi, considering Speedometer reading,
    economy and impact on suspension.
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    nothing bigger than 185/55R15's for your requirements. You could go 205/50R15 but you will experience slight rubbing on your front and rear wheel arches (unless you grind away the inside lips)
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    search for the tire size calculator...or read some reviews in the wheels and tires section. compare ur stock size with the higher size rim and ull get ur answer.
    I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it..and so restriction of free thought and free speech is the most dangerous of all subversions.
    Deloy's Avatar
    Apr 2006
    41
    203
    Best size is 185 with 13 rims, as 14 are a little heavy for vitz, 185 on alloy 13 rims will give you a slightly better bottom clearance and no load on suspension, speedo meter change is hardly noticeable (about 1.7 percent decrease). I am talking personal experience
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    @deloy
    i understand that you are trying to help but you should also state what profile the person should buy otherwise they might end up buying 185/45R13's which would ruin his ride & speedo reading. Just for future refference.
    @mnaeem
    in this case (as @deloy suggested) you'd need 185/70R13's to keep your overall tyre diameter close to stock (4mm larger)
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    good response storm :-)
    portage1's Avatar
    Nov 2005
    hyderabad & Michigan
    10
    21,004
    37 Post(s)
    3 Thread(s)
    @storm.......you the man.
    Rim Size for Vitz -650321
    I'm a freak who lost his mind in the busy world of today and takes his frustration by being funny with others
    Deloy's Avatar
    Apr 2006
    41
    203
    oops,sorry, missed out a critical factor,
    Yup, agree, the size is 185/70R13's
    thanks
    deloy
Closed Thread
