Results 1 to 5 of 5
Thread: Vitz RS meter installation.
    xohaib's Avatar
    Jan 2006
    122
    2 Post(s)
    Default Vitz RS meter installation.
    Hi guyz,
    I got vitz rs meter for my vitz 2001. Currently there is the simple analog meter.
    I want to replace it with the RS meter.
    Problem i have faced is that when i plug the wire jacks into it, it do not work, however the merter is ok.
    The seller said you will require to go the some meter wala to get it working.
    Although the grips are same, but i doubt there might be some change in wires order.
    There are basically 2 grips that plugs into the meter in both cases with almost 16 wires in one grip and 14 in another.
    Anybody here installed the RS meter in his vitz know what i am saying.
    I am looking forward if somebody can help me over it to get it working.
    Thanks,
    Have a great day!
    Pic attached for refrence:
    Vitz RS meter installation -1059931
    faizandawood007's Avatar
    Jan 2012
    Gujranwala
    25
    2,566
    33 Post(s)
    5 Thread(s)
    Bro u there might be wiring difference like ur connectors have different wires setting while this meter need different .. this could b a case
    Can,t think of a better signature
    xohaib's Avatar
    Jan 2006
    122
    2 Post(s)
    @faizan
    Thanks for reply. Yeah that is what the seller told me.. But i want to do it my self so if nybody know whats the exact wire setting for this Rs meter.
    saadkamal's Avatar
    Jun 2008
    27
    120
    my friend got this meters wiring done u wont be able to do it at home its realy difficult and complex and i wont recoment to install the meter *** all ur meter wiring will be cut and redone which accordng to me it not gud but yes if some one does it be grip to grip fiitng without cuttng wires then its great
    engineer6's Avatar
    Dec 2010
    Peshawar
    14
    @xohaib bhai: I have bought RS meter too. And the current one is analog metrr without RPM. Can you please help me change the meter? If you have wiring diagram please share it with me on p080069@nu.edu.pk
Tags for this Thread
